Go Back   Ford Truck Enthusiasts Forums > Diesel > Pre-Power Stroke Diesel (7.3L IDI & 6.9L)
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 10-29-2009, 06:41 PM
crazymike's Avatar
crazymike crazymike is offline
crazymike is starting off with a positive reputation.
Cool installing sencors on my e40d
i need to know the correct instalation procedure for the throttle position sensor, i recently (today) replaced mine and its not exactly right, i can tell this because it has no idea when to shift.
also before and after the new tps i replaced about every sensor and the computer brain to ti, now it shift but my OD light is flashing telling me somthing is wrong.... probly somthing i did any uidea's?
__________________
91 f-250 4x4 280,000+ on the clock. k&n intake, rebuilt strengthened e4od,with 94 style tcu, all sensors new, warn hubs
  #2 (permalink)
Old 10-29-2009, 07:52 PM
M.L.S.C.'s Avatar
M.L.S.C. M.L.S.C. is online now
M.L.S.C. is gaining momentum as a positive member of FTE.
if the TPS is out of adjustment the PCM will not like that and may flash the OD light. To adjust the TPS (also known as FIPL) you have to first warm up the truck, then shut the engine off and put the ignition back on (engine stays off), stick the positive lead of a voltmeter on the middle hole of the TPS plug, put the negative lead of the voltmeter on the negative post of one battery, and measure voltage - you should have no less than 1.0V at idle and no more than 4.5V at wide open throttle (move the throttle arm on the passenger-side of the IP by hand). Loosen mounting screws for TPS bracket and turn the whole thing as needed to get the proper voltages, then tighten screws back down. Many folks recommend setting it to where you have 1.1V at idle.
__________________
Real trucks rattle! '90 F350 XLT Lariat, reg cab, dually, RWD, 4.10s, factory tow package, and lots of add-on goodies.
Quote:
Originally Posted by fx4wannabe
Some guys like there GF more than their truck. Not me. They don't make these trucks anymore, they make new GF's everyday.
  #3 (permalink)
Old 10-30-2009, 11:59 AM
crazymike's Avatar
HOLY FREEKING YAY! that makes me happy. i finaly got to adjust the tps this morning, and the flashing light stopped
i adjusted it to 1.05 at idle just for kicks, and it only went up to 3.2? is the low voltage towards full throttle going to be an issue? or does it not matter since its going to be full throttle?
i notice my shift schedual is weird for me as it holds gears for just a couple rpm's higher before shifting, but thats good.
thanks though that was super helpfull
__________________
  #4 (permalink)
Old 10-30-2009, 04:37 PM
M.L.S.C.'s Avatar
Glad to help out - now please add to my rep
The 3.2V thing - you're essentially limited by how much your throttle arm can turn, there are two set screws on it, one for the idle speed and one for the max throttle, it's recommended that you don't mess with the WOT screw. So I'd suggest that you wait till your engine is all warmed up and then adjust your idle engine speed (shoot for 600-650 rpms), then readjust the TPS so it shows 1.1V at idle, and see where the WOT voltage may fall, and leave it be.
__________________
  #5 (permalink)
Old 10-30-2009, 06:12 PM
David85's Avatar
David85 David85 is online now
David85 is gaining momentum as a positive member of FTE. David85 is gaining momentum as a positive member of FTE.
Ivan, I didn't recognize you with the new avatar. I was thinking, who's the new E4OD guru? *reads name* oh, right. I know him.
"holy freakin'yay!"
Never heard that one before lol.
3.2 seems a little low for full power setting but it sounds like is shifting properly for your base TPS setting. Hope this gets it working once and for all.
__________________
1986 F250HD Ex cab Fresh built up 6.9L diesel, Lariat AC leather seats power everything w/full cluster, sterling rear 3.08LS gears, E4OD trans, ram intake ATS 088 turbo
1986 F150 Ex cab Lariat rollercam 5.0L on LPG AOD trans 3.55 gears 390 000Ks
  #6 (permalink)
Old 10-30-2009, 07:03 PM
M.L.S.C.'s Avatar
Haha David, since many folks put their trucks in their avatars, I figured follow suit. And yeah, 3.2V does seem a bit low, but it's awful close to the minimum recommended WOT voltage of 3.3V (if I remember correct), so I figured he'll be alright.
__________________
  #7 (permalink)
Old 10-30-2009, 07:25 PM
archangel archangel is offline
archangel is new and has a neutral reputation at this point.
Also, if the voltage is out of spec, it might not set the trans pressure at the proper pressure and you might have longevity issues.
To much or not enough pressure at the wrong time is not good.
__________________
Gray 1991 F250 standard cab, 7.3, E4OD, 3.55:1, stock wheels and tires.
Verified 19 mpg city taking off slow as hell the shutting down at red lights, and with the radiator grill blocked flush, no bed cover, "drag shoot" mirrors on I get 24 mpg at 50 to 55 mph on the freeway empty!
However, with a bed cover, no mirrors and Hydroxy
  #8 (permalink)
Old 10-30-2009, 09:48 PM
johnboggs21's Avatar
johnboggs21 johnboggs21 is offline
johnboggs21 is starting off with a positive reputation.
Quote:
It is kinda weird not seeing that freaky fish thing anymore. lol
__________________
1993 F-250HD 7.3L IDI E4OD
I'm gonna sign my name in that diesel smoke and let the ones that come along behind me choke!
Tags
1997 , 73 , 97 , adjust , adjusting , arm , e40d , f150 , f250 , f350 , ford , installing , position , sensor , shift , throttle , thunderbird , tps , voltage
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
