Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1980 - 1986 F100, F150 And Larger F-Series Trucks
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1980 - 1986 F100, F150 And Larger F-Series Trucks SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 10-29-2009, 05:58 PM
Greyf100's Avatar
Greyf100 Greyf100 is offline
Greyf100 is starting off with a positive reputation.
tire question
will a 31x10.50r15 tire fit on an '81 f100 2wd?
thanks, Rob
anyone have any pics of that size on a 2wd truck without a lift?
  #2 (permalink)
Old 10-29-2009, 11:29 PM
broboon525's Avatar
broboon525 broboon525 is offline
broboon525 is starting off with a positive reputation.
I am not sure about a 1980, but, I run them on my 1981 f150 with no problems or no lift. Look at my profile they are on the avatar I use.
__________________
1981 f-150 302/C6 9"
I believe in gun control and what better gun control is there than a bullseye!
Louisiana Chapter Member
  #3 (permalink)
Old 10-29-2009, 11:32 PM
ozzy_2_me ozzy_2_me is offline
ozzy_2_me is starting off with a positive reputation.
i have an 86 with thos on it and i have no lift and no problems. but. everytruck is different. even though it might bet the same year make madel ect.... i strongle recamend to test fit the tire on the front to see if it clears everything. turning side to side
  #4 (permalink)
Old 10-29-2009, 11:50 PM
FordNFishinLover's Avatar
FordNFishinLover FordNFishinLover is offline
FordNFishinLover is starting off with a positive reputation.
Pretty sure thats the max size tire you can fit on it without a lift and without it rubbin
__________________
1981 Ford f-100 302 windsor/C6/3.25/9.0 rear
Bass, walleye, catfish, and trout, im tellin you now you'd better look out! You were safe in the lakes when i was home wishin. But be on your guard cause im goin fishin!
  #5 (permalink)
Old 10-30-2009, 10:42 AM
NavyMIDN08's Avatar
NavyMIDN08 NavyMIDN08 is offline
NavyMIDN08 is starting off with a positive reputation.
i had 31x10.5x15 on mine for a long time. when the suspension flexed enough it would rub some, but never enough to cause a problem, and only with a lot of flex. shouldn't be a problem unless you want to take it rock-crawling....
__________________
If it ain't broke, you ain't worked it hard enough...
  #6 (permalink)
Old 10-30-2009, 11:14 AM
Greyf100's Avatar
no rckcrawling with the 2wd truck...that is saved for..
  #7 (permalink)
Old 10-30-2009, 10:13 PM
Cienega32 Cienega32 is offline
Cienega32 is starting off with a positive reputation.
Exact tires and truck for me. They rubbed the radius arms somewhat now and then and were fussy when tight turning. I just changed them out to 30x9.50 and all is good, it seems. Both sets - BFG T/A.
http://i479.photobucket.com/albums/r...i-P3137359.jpg
  #8 (permalink)
Old 10-31-2009, 04:13 AM
papa86f150 papa86f150 is offline
papa86f150 is starting off with a positive reputation.
I got 32 on my 86 4x4. They do rub when the truck is flexed but i like them.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
