Go Back   Ford Truck Enthusiasts Forums > Misc. > Clutch,Transmission, Differential, Axle and Transfer Case
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 10-29-2009, 04:45 PM
Lukes66 Lukes66 is offline
Lukes66 is starting off with a positive reputation.
M5OD Noisy in all gears but 4th
I have a 95 Ranger 2wd with 3.0 and M5OD. The truck has 209,000 miles. It started making a whining gear sound in all gears except for 4th. I checked the fluid and it is full of clean ATF. The sound got worse (scary) after a few days. I called my favorite yard looking for a transmission before I decided to have this one repaired and they didn't have one. They said they get them all the time and they sell fast for 400 bucks! Sounds expensive to me. Anyway now the trucks sittin in front of a transmission shop about to get tore down. How bad is this? All the transmission shop guy said is it will be a minimum of 300 bucks.
__________________
Luke
1952 F1
1995 Ranger
  #2 (permalink)
Old 10-29-2009, 05:24 PM
l-m tech l-m tech is offline
l-m tech is gaining momentum as a positive member of FTE.
SOUNDS LIKE THE COUNTERSHAFT BEARINGS ARE JUNK.WHEN ITS IN 4TH THATS 1 TO 1 RATIO,STRAIGHT THREW THE INPUT SHAFT TO THE TAILSHAFT.WHEN YOU SELECT THE OTHER GEAR THE POWERFLOW IS TRANSFERED FROM THE INPUT SHAFT TO THE COUNTER SHAFT TO THE OUTPUT SHAFT,THUS GIVIN YOU THE NOISE.
__________________
ASE MASTER TECH FORD SENIOR MASTER TECH
  #3 (permalink)
Old 10-30-2009, 02:21 PM
I went to the transmission shop today to see how things are going and they had the transmission out. They said the pilot bearing was so trashed it was basically disintegrated and that the input bearing was making noise. The shaft is buggered up to. I am supposed to find out more tomorrow after they open it up. We haven't discussed cost yet so I am nervous. Anyone care to take a stab at what the cost will be?
__________________
Luke
1952 F1
1995 Ranger
  #4 (permalink)
Old 11-02-2009, 08:34 AM
FORGOT ABOUT THE POCKET BEARING.WAS THE TRANS LOW ON FLUID.USUALLY THE SHIFT RAIL SEALS WILL LEAK AND CAUSE A LOSE OF FLUID.
__________________
Tags
m5od
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
