Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 1997 - 2003 F150
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1997 - 2003 F150 1997-2003 F150, 1997-1999 F250LD, 7700 & 2004 F150 Heritage SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 10-29-2009, 03:53 PM
Tweetot Tweetot is offline
Tweetot is starting off with a positive reputation.
2002 F-150 V-6
Hey All,
I have a 2002 F-150 Super Cab with a 4.2L V-6. It has 168K Miles and is very well maintained. Most mileage is over 55MPH Highway nothing over 75mph. The engine has a slight miss (almost a shudder) when slowly accelerating between 1400 and 1500 rpms. I changed the Coil Pack, EGR Valve, wires and plugs but the problem remains. I checked fuel pressure in the rail and it is steady as a rock @ 30psi. I get a OBDII code "0305" which is a miss on cylinder #5 but this code doesn't seem to coincide with the missing. I can clear the code, rev it a few times and go through the shudder and no code. Then as I am accelerating sometimes the code will set. I am really baffled as to what can cause a cylinder misfire code on only one cylinder only between 1400 and 1500 rpms. I cleaned the injector plug connections and it didn't help. I am almost tempted to just change the #5 injector thinking it could be an impedance breakdown at that certain frequency.
Any ideas? I checked all vacuum lines and connections for some vacuum leaks but again, nothing showed up.
Truly lost.
Tweetot
  #2 (permalink)
Old 10-29-2009, 04:12 PM
thomastl thomastl is offline
thomastl is starting off with a positive reputation.
My guess would be the fuel injector on #5.
Swap it with #4 and see if the problem moves.
Or depending on price just go ahead and buy one and install.
  #3 (permalink)
Old 10-29-2009, 04:19 PM
bokker bokker is offline
bokker is starting off with a positive reputation.
hi, i seem to remember that the intake manifold bolts / rubbers take a set and cause a vacuum leak etc. replacement may help.bokker.
  #4 (permalink)
Old 10-29-2009, 06:43 PM
LxMan1's Avatar
LxMan1 LxMan1 is offline
LxMan1 has much to be proud of LxMan1 has much to be proud of LxMan1 has much to be proud of LxMan1 has much to be proud of LxMan1 has much to be proud of LxMan1 has much to be proud of LxMan1 has much to be proud of LxMan1 has much to be proud of
The PCM has to see the misfire for a certain amount of time before throwing a code.
I would swap the two injectors as mentioned and see if the code follows the injector.
A compression test wouldn't hurt either. Hopefully, there isn't coolant seeping into the cylinder and fouling the plug.
__________________
Jimmy- FTE Moderator
Support FTE....Online Store
88 5.0 LX Mustang
63 F100 351W/C6
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
