Go Back   Ford Truck Enthusiasts Forums > Small Chassis Trucks > Explorer, Sport Trac, Mountaineer & Aviator
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Explorer, Sport Trac, Mountaineer & Aviator 1991-1994, 1995-2001, 2002-2005, 2006-2010 Ford ExplorerSPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 10-29-2009, 03:12 PM
country dad country dad is offline
country dad is starting off with a positive reputation.
PLEEEEEASE HEEEEELP MEEEE
oK, im going nuts.. I have a 2000 ford explore sport, v6 4.o ohv..
My battery light is on, Now I have a new alternator, new battery, but yet the light still stays on, Plus my radio will not work now, OK, I took the truck to auto zone and they said no juice is getting to the battery.. What do I do, Is there a fuse I dont know about or something? Please help me.. Thanks
  #2 (permalink)
Old 10-29-2009, 03:31 PM
scucci's Avatar
scucci scucci is online now
scucci is starting off with a positive reputation.
175 amp mega fuse in distribution box. Also check battery ground wire to body and frame. Fuse I.D. and locations are in the owners manual.
  #3 (permalink)
Old 10-29-2009, 03:39 PM
175 mega fuse
Quote:
If the mega fuse is bad, would the hole truck not work...
  #4 (permalink)
Old 10-29-2009, 06:06 PM
scucci's Avatar
Quote:
schematic shows 175 amp fuse as the only connection from alternator output to battery. The battery cable goes to the power bus in the distribution block also. So that would indicate ther would still be power to the rest of the truck. Here is the tree for t-shooting from the service DVD:
The Charging System Warning Indicator is ON with the Engine Running (The Battery Voltage Does Not Increase) 4.0L possible sources:
  • A Circuit 36 (Y/W).
  • A Circuit mini-fuse.
  • B+ Circuit 38 (BK/O).
  • B+ fuse link.
  • I Circuit 904 (LG/R)
  • Voltage regulator.
  • Generator
1: Check A circuit mini Fuse 24 (15A) in power distribution box.
OK -go to 2
2:Measure the voltage between the B+ terminal on the generator, Circuit 38 (BK/O).
  • Is the voltage equal to battery positive voltage (B+)?
Yes
GO to A3 .
No
REPAIR Circuit 38 (BK/O). TEST the system for normal operation.
3:
Measure the voltage between generator connector Pin C-121-A Circuit 36 (Y/W) and ground.
Yes GO to A4 .
No REPAIR Circuit 36 (Y/W). TEST the system for normal operation.
4: NOTE: The voltage regulator (VR) (10316) must be connected to the wiring harness for this test.
  • Measure the voltage between the generator I-terminal, Circuit 904 (LG/R) and ground.
  • Is the voltage greater than 1 volt?
Yes GO to A5 .
No REPAIR Circuit 904 (LG/R) for an open or short. TEST the system for normal operation.
5:A5 CHECK THE GENERATOR OUTPUT
With the engine running, ground the F pin on the generator/regulator.
  • Does the battery voltage increase and the charging system warning indicator turn off?
Yes REPLACE the voltage regulator. TEST the system for normal operation.
No REPLACE the generator (GEN) (10300). TEST the system for normal operation.
Tags
175 , 1995 , 97 , box , charging , distribution , explorer , f150 , ford , fuse , location , mega , power , replace , system , test
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
