Go Back   Ford Truck Enthusiasts Forums > Diesel > 2003 - 2007 6.0L Power Stroke Diesel
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
2003 - 2007 6.0L Power Stroke Diesel SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 10-29-2009, 02:56 PM
dmanser dmanser is offline
dmanser is starting off with a positive reputation.
6.0 Oil Temp
Can anyone tell me what the normal Oil Temp should be on a 2004 6.0. I think this is an early 6.0.
Thank for any input.
  #2 (permalink)
Old 10-29-2009, 03:23 PM
texans's Avatar
texans texans is offline
texans is gaining momentum as a positive member of FTE.
It should run pretty close to the ect. Around 190 or so.
__________________
2006 F-250 Lariat C.C, 18" rockstars w/285/65 nittos, SCT w/custom tunes, Banks Ram-Air Intake, 5" MRBP exhaust w/o kitty, 2.5" levealing kit, readylift air bags, fumoto drain valve, Viper alarm with remote start, 2-10" MTX Subs, drilled and sloted front rotors, ARP studs sitting in shop waiting on other parts.
come Join the Texas Chapter!!
Scotty
  #3 (permalink)
Old 10-29-2009, 03:37 PM
speedracer1000's Avatar
speedracer1000 speedracer1000 is offline
speedracer1000 is starting off with a positive reputation.
oil temp shouldnt vary more than 15 degrees from the water temp. on the higher end. if it continues to climb the more you drive it. you have a plugged oil cooler on the coolant side.
  #4 (permalink)
Old 10-29-2009, 04:33 PM
Thanks for the replies, I figured that was the case but wanted to be sure. It's running up to 230 and the water is around 190. I just had the Hi pressure pump replaced last week and got hosed by the shop. Now I was on the road and it just lost all power, like no turbo at all. I took it back to the shop that repaired it and they said you need a new cooler with an est. of 2k to do it. I love my truck, but I just drop 5k in a month and now this....
  #5 (permalink)
Old 10-29-2009, 04:41 PM
69cj 69cj is offline
69cj has a good reputation on FTE. 69cj has a good reputation on FTE.
Sounds like you need a new shop
__________________
"05 F-250, 6.0, CC, LB, 3.73, Lariet, with coolant filter and Bilstein shocks, Magnefine p.s. filter, S. Ca.
"69 Mustang, Mach 1, 428 CJ, Ram Air, Stock
"71 Triumph Trident
2007 Thor Jazz 5er, 11k, 31'
173rd Abn.
  #6 (permalink)
Old 10-29-2009, 06:25 PM
SteveBricks's Avatar
SteveBricks SteveBricks is online now
SoCal Chapter LDR
2006 Ford F-250
My Garage
SteveBricks has a superb reputation SteveBricks has a superb reputation SteveBricks has a superb reputation SteveBricks has a superb reputation SteveBricks has a superb reputation SteveBricks has a superb reputation SteveBricks has a superb reputation SteveBricks has a superb reputation SteveBricks has a superb reputation SteveBricks has a superb reputation SteveBricks has a superb reputation
That's the truth.
Where in SoCal are you?
__________________
NHRDA #4698
SoCal FTE
Join our Chapter *HERE*
9/21/54 - 9/25/09
  #7 (permalink)
Old 10-29-2009, 07:34 PM
La Mirada, CA
  #8 (permalink)
Old 10-29-2009, 07:55 PM
SoCal Chapter LDR
2006 Ford F-250
My Garage
If you want a different shop and you don't mind driving down to Mission Viejo I'd recommend Bud at OC Diesel Shop: OC Diesel Shop - Home of Bud
Excellent tech, and a great guy to work with.
__________________
NHRDA #4698
SoCal FTE
9/21/54 - 9/25/09
  #9 (permalink)
Old 10-29-2009, 08:07 PM
Thanks, I just sent him a e mail. It's really hard to find good honest shops anymore. I have a few other thing I want to do, I just been waiting to find the right shop I can trust. Again, Thanks
  #10 (permalink)
Old 10-29-2009, 08:16 PM
SoCal Chapter LDR
2006 Ford F-250
My Garage
Let us know how it works out for you
__________________
NHRDA #4698
SoCal FTE
9/21/54 - 9/25/09
  #11 (permalink)
Old 10-29-2009, 10:15 PM
cheezit cheezit is offline
cheezit is gaining momentum as a positive member of FTE.
normal unloaded operating temp is 212 degress ect. eot should be with no more then +15 of that. operating temps around 220 are not uncommon.
Tags
60 , diesel , ford , normal , oc , oil , operating , shop , specs , temp , temperature
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
