Go Back   Ford Truck Enthusiasts Forums > Diesel > Pre-Power Stroke Diesel (7.3L IDI & 6.9L)
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 10-29-2009, 02:54 PM
aroulette aroulette is offline
aroulette is starting off with a positive reputation.
Trying to take starter off my 7.3 1989 motor
I have all 3 bolts out and connections to cylanoid off. Now I cant get it to slide out of its place. I have pulled and pulled. What is the trick?
  #2 (permalink)
Old 10-29-2009, 03:48 PM
M.L.S.C.'s Avatar
M.L.S.C. M.L.S.C. is offline
M.L.S.C. is gaining momentum as a positive member of FTE.
Is it stuck to the engine adapter plate? Or it's loose, but you just can't wiggle it out of there?
__________________
Real trucks rattle! '90 F350 XLT Lariat, reg cab, dually, RWD, 4.10s, factory tow package, and lots of add-on goodies.
Quote:
Originally Posted by fx4wannabe
Some guys like there GF more than their truck. Not me. They don't make these trucks anymore, they make new GF's everyday.
  #3 (permalink)
Old 10-29-2009, 08:54 PM
Dave Sponaugle's Avatar
Dave Sponaugle Dave Sponaugle is offline
1986 Ford F-250
Dave Sponaugle is a name known to all Dave Sponaugle is a name known to all Dave Sponaugle is a name known to all Dave Sponaugle is a name known to all Dave Sponaugle is a name known to all Dave Sponaugle is a name known to all
You must have the long and skinny Mitsubishi starter.
Does it look like this?
And your trouble is the cross member is right in the way.
You need to turn the starter just a little at a time, when you get it in exactly the right place it will drop right out.
Try to pay close attention to how it is turned when it comes out, that is how it has to go back in.
I just swapped mine this summer, if I remember right turn the solenoid on top away from the motor just a little.
__________________
86 F250 HD 6.9 IDI ATS turbo "not exactly" stock 4x4 T19 BW1345 3.55LS both ends D60 front, 10.25" Sterling rear, ram air, dual stacks.
"I dig dirt"
FTE Guidelines
FTE Moderator IDI diesel forum
WV Chapter Member
  #4 (permalink)
Old 10-30-2009, 11:00 AM
Bolt
That ever elusive 3rd bolt that i said, "thats not hard to reach" was the wrong on and I still had a bolt attached. Its off and ordered a new one
  #5 (permalink)
Old 10-30-2009, 07:14 PM
archangel archangel is offline
archangel is new and has a neutral reputation at this point.
I don't see why that engineer did not put that hard to reach bolt in from the back side where we can reach it!
Last time I pulled the starter, I decided that next time the starter had to come out, I would drill it out, tap it myself and get the correct replacement bolt to correct the issue.
__________________
Gray 1991 F250 standard cab, 7.3, E4OD, 3.55:1, stock wheels and tires.
Verified 19 mpg city taking off slow as hell the shutting down at red lights, and with the radiator grill blocked flush, no bed cover, "drag shoot" mirrors on I get 24 mpg at 50 to 55 mph on the freeway empty!
However, with a bed cover, no mirrors and Hydroxy
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
