Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460)
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 10-29-2009, 01:39 PM
crazyeddie's Avatar
crazyeddie crazyeddie is offline
crazyeddie is starting off with a positive reputation.
Swap for EFI Intake? + Bonus Material
I was browsing intakes on ebay and came across this:
FORD 460 ALUMINUM INTAKE MANIFOLD FUEL INJECTION obo:eBay Motors (item 110443281598 end time Nov-06-09 12:54:18 PST)
While doing some research on the Edelbrock Streetmaster I was thinking of topping off my 460 with, I came across a few intake manifold dyno comparisons and they all showed the same results: The stock intake manifold was out-performed only by the Edelbrock Performer (by a very small margin) on a stock to mildly modified 460.
All single-planes they tested lowered the dyno numbers (they'd work nice on a motor with some compression and a big cam though) so I'm thinking about scratching the Streetmaster.
Since buying an Edelbrock Performer is about $200 over my budget ( I'm such a tightwad...) I was thinking about getting my hands on an EFI intake - there's a handful of them in my local junkyard just like the one on ebay. Same performance as my cast intake, it's lightweight, looks pretty, etc.
The injector bosses would have to be plugged (no biggie right?) and I can machine a spacer plate to bolt the carb down to.
Question 1: Will the manifold mate to my '76 heads?
Question 2: Is the EFI manifold split-plenum? (Hard to tell from the pics on the ebay listing whether it's split plenum or just has the divider cast into the surface of the throttle-body base)
Question 3: Is this a crazy idea?
I was also thinking if the intake is actually open plenum, I can machine the base divider off and fab a full divider to make it a split plenum intake. I read an article in Hot-Rod Engines - they put a divider in an open plenum intake which is supposed to artificially create torque by amplifying the intake pulses and their dyno verified an additional 13ft/lbs on a Chevy v6.
And while skimming the same magazine, they found blocking off the intake's heat riser made a dyno verified 26hp in a Mopar 440!
I read too much. I type too much too. At least I ain't readin' no Harry Potter though
Halp! I need ideauhz!
__________________
People work from sun to sun but a gearhead's work is never done. -An old mechanic's adage
  #2 (permalink)
Old 10-29-2009, 04:43 PM
jarod17's Avatar
jarod17 jarod17 is offline
Nevada CL
jarod17 is gaining momentum as a positive member of FTE.
I will answer your question in order.
1. No the EFI manifold will not mount up to the carbed (or pre efi) heads.
2. Having not taken my engine apart yet I do not know.
3. If it works is it realy crazy?
Why not convert to efi?
__________________
Jeff-Nevada Chapter Leader
Tell me I can't do it or it can't be done I will go out of my way to prove myself right.
People who say it can not be done, should not interrupt those who are doing it. Tom Monson
1996 F-250 4X4 460, 3.55, e40d
1985 D-350 Eventually going to have a Turbo Cummins
1971 F-250 Eventually going to have a 7.3 turbo Powerstroke out of a '99 or newer F-250
  #3 (permalink)
Old 10-29-2009, 11:03 PM
Bear 45/70's Avatar
Bear 45/70 Bear 45/70 is offline
Bear 45/70 has a good reputation on FTE. Bear 45/70 has a good reputation on FTE.
Quote:
And lose all ability to improve the engine's performance for a reasonable amount of money.
__________________
Bear 45/70 Gimp Racing <a href=http://i145.photobucket.com/albums/r206/Bear-45-70/Emoticons/icon_weelchairbb.gif target=_blank>http://i145.photobucket.com/albums/r...eelchairbb.gif</a>
“There are only two things stopping you, common sense and fear! And not much of the latter.”
  #4 (permalink)
Old 10-30-2009, 09:46 PM
crazyeddie's Avatar
And there's nothing I can do to make it fit the heads? Crap this blows!
__________________
Tags
efi , ford , intake , manifold , truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
