Go Back   Ford Truck Enthusiasts Forums > Small Chassis Trucks > Explorer, Sport Trac, Mountaineer & Aviator
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Explorer, Sport Trac, Mountaineer & Aviator 1991-1994, 1995-2001, 2002-2005, 2006-2010 Ford ExplorerSPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 10-29-2009, 01:30 PM
Kongslibakken's Avatar
Kongslibakken Kongslibakken is offline
Kongslibakken is starting off with a positive reputation.
96 Explorer Starting Problem
Can anyone help me out I have a 1996 Explorer Sport 4.0 with a Manuel Transmission. It just clicks at the solenoid on the fender. I have replaced two solenoids and we had the starter out and it Bench tested fine at the Parts House. The wires all look good the Battery connections are tight and clean and the Battery checks out fine. What am I missing I am about to pull the starter for the second time. The starter connection wires are clean and tight also. I,m thinking it just might be a tempermental starter. but is there anything I am missing. Thanks in advance. KB
__________________
When I figure out what I'm doing I'll let you know.
  #2 (permalink)
Old 10-29-2009, 01:54 PM
shorod's Avatar
shorod shorod is offline
shorod is starting off with a positive reputation.
Is the solenoid on the fender clicking rapidly when the key is held to "Start" or just a single click until you release the key?
If it's a rapid click, the problem is likely a voltage/current issue to the solenoid. What does the system voltage do when trying to start the vehicle?
If it's just a single click until you release the key, the problem is likely between the solenoid and the starter. Have you confirmed voltage is getting to the starter? Can you carefully measure voltage to the starter while another person turns the key to "Start?"
-Rod
  #3 (permalink)
Old 10-29-2009, 02:03 PM
aquanaut20's Avatar
aquanaut20 aquanaut20 is offline
aquanaut20 is starting off with a positive reputation.
Quote:
Yes, You need to get the VOM out and verify the circuit. Battery+ all the way to the starter, through the solenoids to the main stud entering the starter case. Also check 12vdc @ the exciter lug (small wire on starter, from ignition key start position)
Report back
__________________
97, 4Dr, Controltrac, X engine, 360k
  #4 (permalink)
Old 10-30-2009, 02:28 PM
marragtop marragtop is online now
marragtop is starting off with a positive reputation.
You can also try bypassing the solenoid with a jumper to see if that makes a difference.
__________________
'88 F150 4x4
'91 Explorer XLT 4x4
'92 Explorer XLT 4x4
'95 Explorer XLT 4x4
If it don't = 16 (4x4), it ain't worth driving...
  #5 (permalink)
Old 11-06-2009, 08:27 AM
Ok it is fixed the problem was the exciter wire I had power to it with the test light but when I hooked it to the starter the spade end was not making contact with the blade on the starter. It looked a little funny so I replaced the spade terminal and walla she starts every time Thanks Guys this one was making me crazy.
__________________
  #6 (permalink)
Old 11-06-2009, 10:25 AM
aquanaut20's Avatar
Glad to be of assistance, thanks for reporting back
__________________
Tags
1996 , 96 , excitor , explorer , ford , mountaineer , post , problem , problems , solenoid , spade , starter , starting , truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
