Go Back   Ford Truck Enthusiasts Forums > Diesel > 1994.5 - 1997 7.3L Power Stroke Diesel
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1994.5 - 1997 7.3L Power Stroke Diesel SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 10-29-2009, 12:58 PM
dstad dstad is offline
dstad is starting off with a positive reputation.
97 7.3 no start :(
drove the truck about a 20 miles yesterday towing , got back to the shop shut it off and now it wont start. The reservoir at the front of the engine is full, the engine oil is full,the battery's are good, the tach goes up to about 250 when cranking, i have oil pressure while cranking but still no start. Its acting like its not getting fuel but it has fuel at the schrader valve. What could be the issue?
I use the truck everyday for work and im dead in the water without it. its a 97 f250 4x4 non extended cab with a built auto. It is completely bone stock.
  #2 (permalink)
Old 10-29-2009, 01:16 PM
Kijutsu's Avatar
Kijutsu Kijutsu is offline
Kijutsu is starting off with a positive reputation.
Couple of things... I'll admit I know nothing about diesel motors.. however...
1. check the fuel bowl, make sure that it's getting fuel up there.
2. check codes on the computer, see if it's throwing any. (autozone should be able to check for free with their scanners.)
3. try the f250 diesel forum, you may have better luck there. this particular one is just 97-03 F150s gas engines.
4. hope you find the problem and get you're truck up and running.
FYI: 1994.5 - 1997 7.3L Power Stroke Diesel - Ford Truck Enthusiasts Forums is a link to the 94.5 - 97 7.3 Diesel forum.
Good luck
__________________
1998 F-150 4x4 4.6L Automatic
- Custom Sound System
- MasterLock Hitch
1993 Ranger 4x2 2.3L 5 Speed
- V8 Swap Coming
  #3 (permalink)
Old 10-29-2009, 02:33 PM
redwood's Avatar
redwood redwood is offline
2002 Ford F-150
redwood is starting off with a positive reputation.
Definitely confirm this in the other forum, but I'd lay my bets on the cam position sensor.
__________________
WCB
2002 Ford F-150 XLT FX4, 5.4L, Automatic
2010 Ford Escape XLS, 2.5L Duratec, Automatic
1948 Willys CJ2A, V6 Dauntless, Standard tranny
  #4 (permalink)
Old 10-29-2009, 02:50 PM
Ron W.'s Avatar
Ron W. Ron W. is offline
Ron W. is starting off with a positive reputation.
Quote:
That would be a good guess, another guess would be the glow plug controller.
__________________
In automotive since 1973, Ford from 1992 to 2006
ex-Ford dealership employee
  #5 (permalink)
Old 10-29-2009, 08:03 PM
b1corr b1corr is offline
b1corr is starting off with a positive reputation.
The Cam position sensor and crank position sensors are quite often the problems with this kind of situation. I had the problem on my 1999 power stroke and my brother had the same problem with his 1999 F150 with the 4.6Ltr engine.
  #6 (permalink)
Old 10-29-2009, 08:28 PM
Hussler's Avatar
Hussler Hussler is offline
Hussler is gaining momentum as a positive member of FTE.
Read your other post but will go with this one. To determine the problem we will need some additional information.
First what is your fuel actual pressure? If you don't have a real pressure gauge then go get a cheap (stick type) tire gauge that can read 70-80 or above psi. While cranking read the pressure on it and it needs to be 20 PSI or above just to start. Usually it would be much more than that.
If that indicates good then we will go to step two. I need to take off and run to the hospital and see my sister but will check in in an hour or so. Next step I can throw some pictures at you on different sensors you can unplug to try and isolate the problem further.
__________________
Jim
1997 F250 HD CC 4x4 7.3L - E4OD - 3.55's
EVBP Disconnected - Napa 6637 - FPR Shim
3" Down Pipe & CD - 203 Stat - 163 K Miles
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
