Emergency Fuel Shutoff Question - Ford Truck Enthusiasts Forums
Old 10-29-2009, 10:56 AM
TES TES is offline
TES is starting off with a positive reputation.
I have a 2002 F-150 5.4L that is a second truck and has only 16,000 miles.
I live 30 mi. S. of Atlanta and had to go 30mi. N. of Atlanta to carry my wife to
the hospital for test. We stopped at the Varsity on the way back in Atlanta.
Truck has been running fine since I bought it new. We went inside and ate. 30 min.
later got in truck to start home, turn key, engine turns over but would not start.
Waited 5 mins. tried again same results. After a few tries, never did fire off. popped hood. Stranded in downtown Atlanta with an ailing wife (very helpless feeling),
nothing amiss, no loose wires, plenty of juice in battery. One in a million chance.
A man walking by saw what I was doing. He worked for a local Ford dealer, said to hit
fuel reset button, he stopped and helped me, checked the valve under the hood while I
turned the switch on, he then pulled the panel on the passenger side and reset the
fuel shutoff. Truck fired up and ran fine all the way home. I thanked him and bought
his lunch.
Question is, What caused my fuel to shutoff and should I have a diagnostic check done.
I don't want to have this happen again, especially if the wife is alone in the truck.
At least now I know where the Schrader valve is and how to reset the fuel shutoff,
thanks to a caring stranger. He saved my bacon.
Many thanks in advance.
Old 10-29-2009, 11:09 AM
redwood's Avatar
redwood redwood is offline
redwood is gaining momentum as a positive member of FTE.
The emergency fuel shut off switch under the passenger kick panel will pop when it is jarred. It's designed to shut the fuel system off in an accident. If you're worried it might be bad, then I'd replace it. It's easy to get to, and easy to replace. It's called a fuel pump inertia switch at Autozone and it's $30. I don't know what could've made it pop if the truck wasn't bumped, but it's just a push of a button to get it going again...
Old 04-18-2011, 03:25 PM
georay georay is offline
georay is starting off with a positive reputation.
possible fuel problems
i have a 2006 f 150 4.2 liter yesterday it just quit in costco parking lot it turns over and fires a little bit but it won't run the tow truck guy said maybe fuel filter now i changed the filter but before i did i turned the engine over see if the pump was working and nothing happened so i seen the emergency shut off i pushed the button in still nothing now one question that shut off switch just went in and out didn't click or set is that the way it works? i checked fuses ok ground cables ok so what will cause the fuel pump not to work? or where should i look next?
thanks for the help !!!!
2008 Expedition Fast Crank, no start..... pharmadave 2007 - 2014 Expedition & Navigator 0 08-18-2014 09:57 AM
Broke down on road Vinford 1997-2006 Expedition & Navigator 2 11-12-2013 08:46 PM
87 F150 fuel Problems vcobler 1987 - 1996 F150 & Larger F-Series Trucks 2 10-19-2011 03:26 AM
Fuel Shutoff Switch ? blondag2 Fuel Injection, Carburetion & Fuel System 1 08-22-2008 07:57 AM
Starts then Cuts off Jatrevino4979 New Member Introductions 1 12-10-2006 10:32 PM
Tags
2001, 2002, 2004, 97, f150, ford, fuel, location, pump, reset, schrader, shut, switch, test, valve
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
