Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1967 - 1972 F-100 And Larger F-Series Trucks
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1967 - 1972 F-100 And Larger F-Series Trucks Discuss the Bumpsides Ford Truck SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 10-29-2009, 09:47 AM
clutter clutter is offline
clutter is starting off with a positive reputation.
Question Timing Qs on new EFI Conversion
I am finishing my EFI conversion and am having a little issue with the timing and running. The truck is not streetable yet.
Specs - .030 overbore, E303 cam, stock H.O. intake and MAF, L1C EEC and a MAF, converted Crown Vic. harness.
Problem - With the SPOUT disconnected I can get the engine started and set the timing (currently 10 BTDC) so that the engine runs. When I connect the SPOUT the engine will continue to run for some time and seemingly well but when I shut it off it is very hard to restart. I mean really hard, engine does not want to turn over. I can sometimes get it to crank but most times I have to disconnect the SPOUT to restart.
This is my first EFI conversion (and this little set back has not discouraged me from my next) I have followed the article posted on this site along with diagrams and articles posted on forfuelinjection.com. One thing that I do need to mention is I may only be supplying 8-9vdc to the TFI on pin 3 which is the 12v Start Only.
FYI: I am posting in several other forums to get more coverage so don't be surprised if you see this elsewhere!
Thanks,
  #2 (permalink)
Old 10-31-2009, 01:25 AM
DLP Performance DLP Performance is offline
DLP Performance is starting off with a positive reputation.
Did you already cut the big pink "resistor" wire at the ignition switch & replace it with at least a 16ga. wire to power the coil & TFI?
  #3 (permalink)
Old 11-02-2009, 08:38 AM
Thank you for the reply. I did not cut and replace the wire you mentioned. So, sounds like I have a little more work to do. Do you have any details or other pointers that will help?
  #4 (permalink)
Old 11-02-2009, 01:21 PM
Try that & see what happens. Let us know!
  #5 (permalink)
Old 11-02-2009, 10:13 PM
I think that I am a little closer. I found the issue with the hard starting. I have the timing at 10 BTC. The engine runs very smooth and strong with the SPOUT connected. But, when connected, the engine runs really rough, does not smooth out and as I check the timing I can see it bounce around back and forth as if trying to figure itself out. When I turn off and try to restart with SPOUT connected, the engine fires for a moment but will not run.
Code Scanner test...
KOEO - 565 CANP Sol. Failure (not installed) 558 EVR Failure (not connected)
KOER - Could not perform
  #6 (permalink)
Old 11-03-2009, 07:59 PM
There's an ECM error. Either something's hooked up wrong or the ECM could be bad. The spout harness could be shorted to ground, but shouldn't be, if it's a new harness.
  #7 (permalink)
Old 11-04-2009, 08:18 AM
I made a little more headway last night. I did some reading about the TFI and felt that I could be looking in the wrong direction. So on a whim I disconnected the MAF sensor and it fired right up. KOEO codes were 998 (fault mode) and 157 (MAF sensor low volt). The engine ran rather well and looking at the timing I noticeed it was advanced indicating that the ECM was controling it. I started looking into the MAF wiring but ran out of time. I did verify that I have the right sensor for my ECM.
  #8 (permalink)
Old 11-04-2009, 02:53 PM
Alright. You're getting somewhere. Make sure you have the right pins in the right spots in the connectors.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
