Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Ford Inline Six, 200, 250, 4.9L / 300
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 10-29-2009, 08:52 AM
F-250 restorer's Avatar
F-250 restorer F-250 restorer is offline
F-250 restorer is starting off with a positive reputation.
Engine death
Some of you probably followed my 390 to 300 swap, and then the failing oil pressure on the new rebuild. The engine was first started August 8th, and since day 1 it began to loose oil psi. Now, coming off the freeway, I have 5 psi at idle. I can't help but wonder if the mis alligned cam bearing during the build is the cause of all this. One of the journals was a bit out of alignment, and the bearing needed to be 'sanded' with 600.
Anyway, I have a new block at a pro rebuilder and just cut a check for a large amount. I will post our findings when we tear down the problem engine, so maybe it will help someone avoid the problems I had.
  #2 (permalink)
Old 11-01-2009, 04:24 PM
Well, I had to tear down four 300's before I found one with standard pistons in it.
It is now in the machine shop being bored .030 over, align honed if needed, balanced, block hot tanked and magna fluxed, crank turned .010 under, rods reconditioned and turned .010 under.
RECOMENDATIONS: The rebuilder asked if I would prefer a name brand cam, Isky, Comp Cams, Crane, or should he have one cut to the specs of one of the big names. Any feedback about that?
  #3 (permalink)
Old 11-01-2009, 05:17 PM
gfw1985's Avatar
gfw1985 gfw1985 is offline
gfw1985 is starting off with a positive reputation.
Thats rough! Hope things turn out better this time. I don't mind doing anything once, but come unhinged when I have to do it twice.
Richard
  #4 (permalink)
Old 11-01-2009, 07:41 PM
dustybumpers's Avatar
dustybumpers dustybumpers is offline
owned by fords
1956 Ford F-100
My Garage
dustybumpers is gaining momentum as a positive member of FTE.
I'm happy with my cliffor cam. sorry about your troubles. I would be too mad at this point to build another one.
__________________
Charlie
Join the Maryland Chapter click HERE
  #5 (permalink)
Old 11-01-2009, 07:58 PM
I guess the most irritating thing is not even being certain what caused the 'meltdown' in the first place. I watched the engine go together with careful hospital cleanliness. The only thing that I didn't like was the cam journal alignment and one bearing having to be sanded.
At this point I am beyond anger. I have spent so much $ that now I have to spend more to have a running, dependable truck, and to make my investment pay. That is what I am doing. Although the pressure is slowly dropping, I am hoping it will hold until the new engine is ready.
I had less than 5psi coming off the freeway on the way to the builder's. That instantly convinced me to dump some STP oil treatment--clean sludge--into the engine.
  #6 (permalink)
Old 11-01-2009, 08:49 PM
owned by fords
1956 Ford F-100
My Garage
I took the handle off an electric drill, and adapted it to work on the cam, to use it to instal it. everytime I pass through a cam bareing, I sqiurt stp onto the cam lobes through the lifter holes. quite messy, but it makes sure you are'nt dragging the cam through a dry place. I also squirt it down through every lifter hole when the cam is in place. rub stp all over the lifter before you drop it in the hole. I keep cardboard under my engine stand to catch all the oil run-off, and it gets really soaked by the end of the build. make sure to clean all the oil passages really well before you set the crank.use stp on the crank, and bearings, turn the motor over constantly as you build it, listen for scrapeing, scratching noises. motor should turn over easy the whole time, until you put in the plugs. if not, something is wrong, tear it down and start over again. when you fire it the first time it's going to smoke real bad for about 5 mins, then it will clear after it starts to warm up. I usually start with 3 bottles of stp, and thier all gone when I'm done. I know this is old school, but it works well for me.I have the machine shop do there thing, then I take all of it home, and build the motor myself. that way I know it is as right as it can be, and if not, I know who to blame. in 42 years I have only had 1 motor fail, and the machine shop assembled that one. I wish you lived next door, I would be right there with you, stp running off my elbows. for sure.
__________________
Charlie
  #7 (permalink)
Old 11-01-2009, 09:56 PM
Dusty--
Thanks for the concern. You've given me nothing but good advice. Thanks for all of it. This engine is going to be perfect.
  #8 (permalink)
Old 11-02-2009, 12:25 AM
Harte3 Harte3 is offline
Harte3 is starting off with a positive reputation.
Some old school things have yet to be improved on. Using STP during engine assembly is one of them.
Cam is your choice but I'd lean toward the Isky 256 Super Cam or maybe a Comp 260. What does your machinist think?
__________________
1983 F150 300 I6, Comp Cam 260h and lifter kit, Port/Polished head, Offy DP Manifold, Holley 4160/1848-1 465 cfm, EFI Exhaust manifolds, Walker Y Pipe to 3-Way Cat, generic Turbo Muffler, Recurved DSII, Mallory HyFire 6a & ACCEL Super Stock Coil, Taylor Spiro Pro Wires, EFI plugs.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
