Go Back   Ford Truck Enthusiasts Forums > Diesel > Pre-Power Stroke Diesel (7.3L IDI & 6.9L)
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 10-29-2009, 04:17 AM
David85's Avatar
David85 David85 is offline
David85 is gaining momentum as a positive member of FTE. David85 is gaining momentum as a positive member of FTE.
Tank Type engine heaters
This question might seem odd, but does anyone know if these will run on DC as well as AC?
Zerostart 1000 watt engine block heater tractor truck:eBay Motors (item 230388402806 end time Nov-13-09 12:07:17 PST)
The thermostat and heater element won't care, but I'm not sure about the circulation motor (EDIT: Do they even have one????).
I've found some that list AC/DC, but not all say that and I'm curious.
__________________
1986 F250HD Ex cab Fresh built up 6.9L diesel, Lariat AC leather seats power everything w/full cluster, sterling rear 3.08LS gears, E4OD trans, ram intake ATS 088 turbo
1986 F150 Ex cab Lariat rollercam 5.0L on LPG AOD trans 3.55 gears 390 000Ks
  #2 (permalink)
Old 10-29-2009, 08:03 AM
JesterPgh's Avatar
JesterPgh JesterPgh is offline
1987 Ford F-250
My Garage
JesterPgh is starting off with a positive reputation.
That's the brand I've been looking into, but everything I've found is they only run on AC current.
__________________
____________________________
1987 F-250 4x4, 6.9 ATS turbo, 4 spd
1993 Lincoln Mk VIII, coil spring conversion, 4.6l of fun
  #3 (permalink)
Old 10-29-2009, 06:57 PM
Dave Sponaugle's Avatar
Dave Sponaugle Dave Sponaugle is offline
1986 Ford F-250
Dave Sponaugle is a name known to all Dave Sponaugle is a name known to all Dave Sponaugle is a name known to all Dave Sponaugle is a name known to all Dave Sponaugle is a name known to all Dave Sponaugle is a name known to all
Most of those units use convection to circulate the coolant.
__________________
86 F250 HD 6.9 IDI ATS turbo "not exactly" stock 4x4 T19 BW1345 3.55LS both ends D60 front, 10.25" Sterling rear, ram air, dual stacks.
"I dig dirt"
FTE Guidelines
FTE Moderator IDI diesel forum
WV Chapter Member
  #4 (permalink)
Old 10-29-2009, 09:17 PM
David85's Avatar
Quote:
I only found out about these last night so I know next to nothing about them. Convection alone won't be enough for what I need.
Figured it was too good to be true.
Well if anyone knows of something that will work well on 120-200 VDC including the stat, please chime in.
__________________
  #5 (permalink)
Old 10-29-2009, 10:34 PM
1986 Ford F-250
Would this be any better?
Webasto's DBW 2010 Heating System
http://www.webasto.us/press/en/am_tr...aters_821.html
The bottom one is smaller.
__________________
"I dig dirt"
FTE Guidelines
WV Chapter Member
  #6 (permalink)
Old 10-30-2009, 12:15 AM
Marianna2003 Marianna2003 is online now
Marianna2003 is starting off with a positive reputation.
The Zerostart units use percolation to circulate the fluid. There’s a marble that acts as a one way valve to keep the fluid moving in the right direction. Kim Hotstart uses a similar technique except they use a flapper valve. It should work fine as long as you are reasonable I your expectations.
  #7 (permalink)
Old 10-30-2009, 12:18 AM
As far as the temperature is concerned, The thermostat is a switch that doesn't care what the voltage is doing.
  #8 (permalink)
Old 10-30-2009, 12:41 AM
JesterPgh's Avatar
1987 Ford F-250
My Garage
Recently, when I inquired locally about a Hotstart, I was told those were recalled because they were starting fires in vehicles. Now, I don't know if there's a bit of fact to it, but the local parts store was not selling them anymore. May be something to look into. I never gave it a second thought until right now.
__________________
  #9 (permalink)
Old 10-30-2009, 02:05 AM
David85's Avatar
Those are a little big (and pricy) for what I need, Dave. But that is the basic idea.
I heard that AC switches can be fused in the on position if they are used with DC. Some on on another forum warned me about that and advised me to run a 12V relay to the thermostat and run the higher DC voltage from the relay to the heater element. More complicated, but safer in theory. I'm hoping I won't have to do that but not sure at this point.
Do you know what sort of flow rates could be expected from the heater without having to add an auxiliary pump? I figure I need at least 2 LPM and will only go through a heater core. The thermostat would also be cycling fairly often because the total fluid amount being heated won't be much. Just the core and pipes, with the heater being as close to the core as possible.
__________________
  #10 (permalink)
Old 10-31-2009, 09:12 PM
Sorry I almost duplicated my previous post.
  #11 (permalink)
Old 10-31-2009, 11:03 PM
A relay can control the heater, but the internal switch is the problem. Actually, I don't think the AC/DC current is relevent. The amount is. Asfar as the flow rate is concerne3d, the power input is the determinig factor. 1 KW = 3415 BTU. 1BTU = 1 pound of water raised 1 degree F. The system functions by boiling water, so the output temperature will be 212 F. Assuming you will be operating with 70 F. 142F differemce. 3415 BTU/142 F =24 Pounds per hour ~ 2.88GPH or 0.048 GPM. A ceramic heater in about the same power range would be cheaper to buy and adapt a DC fan to operate it. Just a suggestion,
  #12 (permalink)
Old 10-31-2009, 11:33 PM
David85's Avatar
My idea was to feed 12V to the internal switch, then use that to energize the relay for the actual heating element. There will be easy access to both voltage ranges.
I thought about using a ceramic heater, but those don't work as well from what I'm told. Ceramic heaters are also a bit more of a fire hazard since the surface temperature of the element is higher than on a hot water tank.
I'm tempted to try it and add a pump if needed later on.
Still a ways off before I need to deal with this. I was mainly wondering if a tank type engine heater can run ~120 DC volts.
__________________
  #13 (permalink)
Old 11-01-2009, 07:13 AM
u.f.o u.f.o is offline
u.f.o is starting off with a positive reputation.
I bought one of those tank type heaters, never used it yet ,one end splices heater hose the other end in the block drain plug where ever thats supposed to be? I had years ago a type that spliced in the heater line which worked good.
Tags
2007 , 73 , 73l , add , circulating , diesel , engine , f150 , ford , heater , heaters , installation , reviews , tank , tanktype , truck , type
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
