Go Back   Ford Truck Enthusiasts Forums > Diesel > Pre-Power Stroke Diesel (7.3L IDI & 6.9L)
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 10-29-2009, 01:04 AM
wreckinball's Avatar
wreckinball wreckinball is offline
1994 Ford F-350
wreckinball is starting off with a positive reputation.
issue for a friend.
Fellas,
Got a buddy that needs some help and so here it is. He has a 7.3l i think about 90 or so for age. He said that his truck starts fine and is solid when warm but for the first 10 or so minutes it smokes a fine trail of fumes. Said it looks like he is rolling full throttle kind of like the vapor trail you get when you stomp it. After about 10 minutes of rolling down the road he said it goes away. I figured it might be the IP or an injector that is sticking or fouled when cold?? not sure, any help for my bro would be awesome!
__________________
94 F350 Extra Cab 7.3l IDI NA W/C6. Major mod is the F150 Body(LMAO) my truck makes me laugh and everyone else scratch their heads!
BC Chapter Member
  #2 (permalink)
Old 10-29-2009, 01:09 AM
Dean88's Avatar
Dean88 Dean88 is offline
Dean88 is gaining momentum as a positive member of FTE. Dean88 is gaining momentum as a positive member of FTE.
It could also be a bad thermostat and the motor is running to cool, but most likely bad injector.
__________________
1992 F250 351W E4OD 3.55 Sterling
1988 F250 7.3 C6/underoverdrive 4.10 D70
1980 F100 300 3spd 2.73
1987 F150 302 T18 4.10 (RIP)
American by birth, Southern by the grace of God, Libertarian by choice!!!
  #3 (permalink)
Old 10-29-2009, 01:27 AM
1994 Ford F-350
he said he had a new thrermostat installed by ford, a motorcraft one so i guess it will be the injector. How can he check them or is it time for a new set, as far as canada goes are there any places that sell them for less than what ford quoted him? Something like 140 a piece? cough cough! haha
__________________
BC Chapter Member
  #4 (permalink)
Old 10-29-2009, 03:04 AM
rupejosh's Avatar
rupejosh rupejosh is offline
1994 Ford F-250
rupejosh is starting off with a positive reputation.
rockauto or ebay, probably run you around $30 a piece US
__________________
94 ford f250 7.3 turbo idi headlight mod,electric fuel pump,tinted windows all around,straight piped and 6" stack and sweet camo trim in the cab
  #5 (permalink)
Old 10-29-2009, 10:37 AM
1994 Ford F-350
check this one out, found them last night. www.pensacoladiesel.com. 19.00 a piece for new ones.
__________________
BC Chapter Member
  #6 (permalink)
Old 10-29-2009, 07:16 PM
Dave Sponaugle's Avatar
Dave Sponaugle Dave Sponaugle is offline
1986 Ford F-250
Dave Sponaugle is a name known to all Dave Sponaugle is a name known to all Dave Sponaugle is a name known to all Dave Sponaugle is a name known to all Dave Sponaugle is a name known to all Dave Sponaugle is a name known to all
140 each sounds like Stroke injectors.
__________________
86 F250 HD 6.9 IDI ATS turbo "not exactly" stock 4x4 T19 BW1345 3.55LS both ends D60 front, 10.25" Sterling rear, ram air, dual stacks.
"I dig dirt"
FTE Guidelines
FTE Moderator IDI diesel forum
WV Chapter Member
  #7 (permalink)
Old 10-29-2009, 08:09 PM
99SevenPoint3's Avatar
99SevenPoint3 99SevenPoint3 is offline
99SevenPoint3 is starting off with a positive reputation.
Quote:
x'2
__________________
Zeus
_Early 99 7.3L 6spd F350 Dually 8" inch lift w/22.5's ..hpx,ccv,intank, zoodad -H/M k&n kit,SouthBendClutch, 02 turbo/w WW,intank pump club,Bellowed up-pipes,MKO 5" exhaust
_94 7.3L IDI Factory turbo 5spd F350 (some upgrades)
  #8 (permalink)
Old 10-29-2009, 09:20 PM
1986 Ford F-250
What are the local temps you are seeing?
Down at or below freezing?
Could just be unburnt fuel because of low engine temps.
10 minutes down the road, there is enough heat in the engine for complete combustion.
__________________
"I dig dirt"
FTE Guidelines
WV Chapter Member
  #9 (permalink)
Old 10-30-2009, 12:32 AM
Marianna2003 Marianna2003 is offline
Marianna2003 is starting off with a positive reputation.
Ah again the reason for temperature limiting GPs. You could leave them on for the first 5 miles to help build the chamber temperature without any guess work.
  #10 (permalink)
Old 10-30-2009, 09:49 PM
JHoffman93's Avatar
JHoffman93 JHoffman93 is offline
JHoffman93 is starting off with a positive reputation.
My VW TDI does that. They stay on until the engine goes above 2500 rpm if I am remembering right. But they don't even glow unless the temps are below 40 deg. F. Starts like a charm on compression only when temps are 40+.
__________________
Aircraft Mechanic, Wichita Citation Service Center. Proudly burning B100 from Healy BioDiesel in my 2001 VW TDI and 1993 F250 Ext. cab IDI 2x4 with a 5 spd manual 3.55 gears.
  #11 (permalink)
Old 11-01-2009, 09:37 AM
1994 Ford F-350
Dave,
it is about 36-42 F in the morning here. Sometimes a bit cooler but overall about that. Ford installed a brand new thermostat when they installed the engine, at my request. However it never runs aboue the O in normal unless I am towing. Could it be the thermostat? Should I let it warm up a bit longer? How long is a food warm up? With 70,000 miles should I replace the injectors anyway?
__________________
BC Chapter Member
  #12 (permalink)
Old 11-01-2009, 11:30 AM
1986 Ford F-250
My guess is you have an injector or two that are leaking fuel when they should be closed.
The excess fuel is appearing as white smoke until the engine temp comes up.
Does the white smoke smell like fuel?
If so, then that is pointing to injectors.
When temps get a bit lower, the water from combustion will also make a white trail from the exhaust as it condenses in the cold air.
The look is about the same, but no raw fuel smell to the exhaust.
36 to 42 that might be what he is seeing, but that usually takes a colder temp.
Since fuel prices are getting higher again, I don't wait very long before I start driving.
I just take it very easy with the throttle till the engine temp comes up.
__________________
"I dig dirt"
FTE Guidelines
WV Chapter Member
Tags
1997 , bad , f250 , thermostat
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
