You will also find out that having a CDL puts different requirements on your driving status. For example, in ky, the blood alcohol limit is .08 for most folks, .02 if you have a CDL in your personal vehicle, and ZERO if you are behind the wheel of a commercial vehicle. That's any vehicle with a DOT number on it. You can get a ticket for DUI by simplying washing your mouth out with mouth wash and getting behind the wheel of a DOT licensed vehicle.
Or, having piged out at a salad bar, lots of fruits & vegs will get you above .00.
__________________ Glenn
96 2WD F250 auto, 6637, 7 guages, two trans coolers, 3 1/2" DP-4" exhaust, FS2500 oil bypass filter, 1" turbo housing, rad filter, 6 position TW, 99 IC, syn oil, Elec fuel pump, adrenaline HPOP, 140v IDM, rear disks, Baby Beans Injectors, 203*, 'the cure', dieselsite's trans filter & air bags.
Oldbird,
Are you suggesting that AFTER drinking that "Pigging Out" at a salad bar will remove the alcohol absorbed in the blood stream and bring the reading down to 0.00?
Hmmmmmm!
Rog
__________________ 1997 Red 4X2 CC S/B-3" DP- No Kitty-6637
Cooling Sys. Filter-7 Gauges-6 Pos.PHP Chip
140V IDM-The "Cure"-CCV Mod w/Filter
1.0 Turbo-No EBP-Detroit Locker/Finned Cover
U. S. Gear Exhaust Brake-Ext. plug for Heater &
Cadillac Battery Water-On board Batt. Charger
