Go Back   Ford Truck Enthusiasts Forums > Diesel > Pre-Power Stroke Diesel (7.3L IDI & 6.9L)
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 10-28-2009, 09:50 PM
galute's Avatar
galute galute is offline
galute is starting off with a positive reputation.
Horrible fuel mileage
My truck is getting horrible fuel mileage. As in 8 to 10 depending on how I drive it. I think the timing may be off. It does not start as good as I think it should but it runs great. The line up marks on the fuel pump are way off. The pump is turned to the pass side about 1/2 inch between the marks on the pump and cover. The pump has most likely been swapped at some point but should the marks be that far apart? I don't have the tools to check the timing and can't find anyone near here who does. Is there a way to set the timing without a ferret or whatever it is called?
__________________
1990 F350 4X4 7.3 IDI N/A E4OD. "Bertha"
1999 F350 4X4 7.3 Stroke 6 speed.
Both of em flatbeds.
  #2 (permalink)
Old 10-28-2009, 10:30 PM
87crewdually's Avatar
87crewdually 87crewdually is offline
87crewdually is starting off with a positive reputation.
1/2" is pretty extreme. Usually you only need to move it 1/16 or sometimes less towards the pass side. I'd consider backing it back towards the driverside a little at a time with test drives in between to see if there is improvement.
__________________
87 CCD, 6.9 Banks Sidewinder turbo & ARP studs, fresh pump & injectors, str8 Pipe out the side, worked C-6, 4.56R&P & Laycock/GearVendors Overdrive
  #3 (permalink)
Old 10-28-2009, 10:40 PM
redbrutis redbrutis is offline
redbrutis is starting off with a positive reputation.
The lines don't necessarily have to line up and often don't. They are ther for the installation of the pump and often the pump is adjusted from there. 1/16" is probably about the norm. If it's too far advanced the motor will sound like it wants to blow up. (I've had experience ). Interestingly though, I got my best milage with "over"-advanced timing.
  #4 (permalink)
Old 10-28-2009, 10:43 PM
Quote:
Read his post. He stated 1/2" between the marks. Thats HUGE.
__________________
  #5 (permalink)
Old 10-28-2009, 10:54 PM
galute's Avatar
Just wondering. Are all pumps indexed the same from the factory or does someone mark the cover and pump after they are installed? If they are marked afterwards that could explain why the marks are so far apart if the pump came from a different motor.
__________________
  #6 (permalink)
Old 10-28-2009, 11:00 PM
joe f350's Avatar
joe f350 joe f350 is offline
joe f350 is gaining momentum as a positive member of FTE.
how old are ur flitter
__________________
85 ford f350 lifted 11 inch 37 6.9 t19 my freinds call it the panzer
  #7 (permalink)
Old 10-28-2009, 11:07 PM
The pump itself is marked with the scribe calibrated to be installed on an engine straight up to get it running. From that point it should be timed with either the proper equipment (which alot of shops rarely have anymore) or a good "ear". Some guys will bring the timing mark towards the passenger side 1/32" at a time until at a cold start the engine will have a "power stroke" rattle and warmed up the rattle goes away. You need to know what to listen for to use this method.
__________________
  #8 (permalink)
Old 10-28-2009, 11:31 PM
galute's Avatar
Quote:
So, if I understand you correctly about the marks my timing is way off or the pump is installed incorrectly. I will try harder to find someone with the proper tools to time it. Thanks for the info.
__________________
  #9 (permalink)
Old 10-28-2009, 11:33 PM
galute's Avatar
Quote:
The flitter's were all changed about 2k miles ago when I change oil. LOL
__________________
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
