Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 2004 - 2008 F150
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
2004 - 2008 F150 2004, 2005, 2006, 2007 and 2008 Ford F150's with 5.4 V8, 4.6 V8 or 4.2 V6 engine SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 10-28-2009, 09:41 PM
brazoriastang brazoriastang is offline
brazoriastang is starting off with a positive reputation.
truck won't go inito 4WD after leveling kit
I had an autospring 2" leveling kit installed on my 2006 f150 and now it won't go into 4WD. I flip the knob over and nothing happens, no 4WD light or anything. I am thinking its a pinched or broken vacume line. Has anyone else had this happen?
Thanks
  #2 (permalink)
Old 10-28-2009, 09:47 PM
tylus's Avatar
tylus tylus is offline
Navy Nuclear Mach. Mate
2008 Ford Expedition
tylus has a good reputation on FTE. tylus has a good reputation on FTE.
take a hammer and lightly tap onto the shift motor on the back of your transfer case....then shift into 4x4
the leveling kit install should have had nothing to do with your IWE's.
__________________
2008 Expedition EL - Hers....Bone Stock
2009 Mustang Bullitt - Mine..Not Quite Stock
Currently deployed. See y'all on the flip-side.
  #3 (permalink)
Old 10-29-2009, 04:09 AM
Sako 75's Avatar
Sako 75 Sako 75 is offline
Sako 75 is starting off with a positive reputation.
Check your vacuum lines at the hub and follow them up, into the engine compartment. The installer may have disconnected them and failed to reconnect them upon completion. There is a joint in the line, just behind the plastic wheel well cowl. It is a few inches above the frame.
__________________
'04 F-150 SCab 4X4 5.4 Auto. 138,000 miles. 275/60/20"s. 2.5" TopGunCustomz Strut Extensions. 2" Rough Country Add -a-leaf. Full bed - Full extension drawer - tool box. DI/DO Flowmasters. Edge Evoulution Programmer. Lots of sound stuff. Hard wired GPS, Radar detector and 1000W power inverter. DIY Blacked out headlights. Rocker panel mounted courtesy lights.
  #4 (permalink)
Old 10-29-2009, 11:08 AM
Is the box on the drivers side near the front with 4x4 written on it the ABS system? One of the lines that I thought was a vacume runs from the drivers side hub up to this then it isn't connected to anything and I don't know where it goes. The other vacume line from the drivers side hub runs back to the passenger side and looks ok as do the rest of them. The fuses are ok too, I will probably take the truck to the dealer. They guy that installed the leveling kit said he put it in 4WD afterwards and it worked.
  #5 (permalink)
Old 10-29-2009, 05:39 PM
xjcamaro89 xjcamaro89 is offline
xjcamaro89 is starting off with a positive reputation.
That line up by the ABS block on the drivers side that is a hard plastic line that has a curve to it is supposed to be not connected to anything, its the vacuum vent tube for the 4WD actuator at the wheel.
Read this for more info on the 4WD not working. Especially before you take it to the dealership and dish out money.
http://www.ford-trucks.com/forums/83...then-some.html
  #6 (permalink)
Old 10-29-2009, 10:11 PM
stronger stronger is offline
stronger is starting off with a positive reputation.
Please tap the motor (small windshield wiper looking motor, bolted on to the top of the tranfsercase, crawl under the cab, drivers side) like Tylus suggested.
Guys, he's not getting the 4x4 light to come on when he turns the knob. The indicator light is in no way connected to the IWEs or the vaccume system. Light comes on when the motor shifts.
Tags
2000 , 2006 , 4wd , 4x4 , add , drive , expedition , f150 , installing , kit , leaf , leveling , problems , wheel , wont
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
