Go Back   Ford Truck Enthusiasts Forums > Diesel > 1994.5 - 1997 7.3L Power Stroke Diesel
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1994.5 - 1997 7.3L Power Stroke Diesel SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 10-28-2009, 09:08 PM
blue66tang95f150 blue66tang95f150 is offline
blue66tang95f150 is starting off with a positive reputation.
How to start a PSD that been sitting for a while?
Ok, I am trying to buy a 95 f250 standard cab, 5 speed from an old very sweet widow. It was her husbands truck till he passed away about 5 year ago. The thing is the truck has been sitting for about 2-3 years with out being driven. She said she would go out and start it up till about a year ago. Now its just been sitting there dead ever since. I hopped in it and to my surprise the bats were still up. So I cranked for about 3 seconds and then decided to call it quits. I didn't know if there could be injector damage to them if they didnt have any fuel in them. that was the extent of my trying to start it. It has 128k on it. What is the proper way to start this thing with out damaging anything?
  #2 (permalink)
Old 10-28-2009, 09:13 PM
c00nhunterjoe's Avatar
c00nhunterjoe c00nhunterjoe is offline
c00nhunterjoe has a very good reputation on FTE. c00nhunterjoe has a very good reputation on FTE. c00nhunterjoe has a very good reputation on FTE.
first check the oil to make sure it hasnt collected water. if it looks ok then check the high pressure pump resevoir to make sure its full. (it doesnt have to be but it will take less cranking if its full) with that said just crank it.
__________________
The name's Joe. I blow sheet up for a living, then get paid to fix it, and blow it up again.
http://www.youtube.com/user/c00nhunterjoe
http://community.webshots.com/user/c00nhunterjoe
  #3 (permalink)
Old 10-28-2009, 09:57 PM
pjwoolw's Avatar
pjwoolw pjwoolw is online now
pjwoolw is gaining momentum as a positive member of FTE.
Get yourself a new fuel filter and some Diesel fuel additive of your choice. Pop the cover on the bowl. Drain the bowl by opening the drain valve (yellow thing attached to the bowl). Close the drain valve. Fill the bowl about 1/2 full of your additive and install the new filter. At least that will give it a good shot to start up. Maybe put some fresh fuel in one of the tanks. It may be out of fuel also. This in addition to the suggestions above.
__________________
Pete in San Ramon
2005 F250 6.0 Lariat 4x4 CC Short bed (stock)
1997 F250 7.3 XLT 4X4 Reg. cab (stock)
1986 F250 6.9 XLT Gone but not forgotten
  #4 (permalink)
Old 10-28-2009, 10:05 PM
Hussler's Avatar
Hussler Hussler is offline
Hussler is gaining momentum as a positive member of FTE.
Charge the battery's up. These things need to spin over fast to start. After sitting that long they might turn the engine over but probably not fast enough.
__________________
Jim
1997 F250 HD CC 4x4 7.3L - E4OD - 3.55's
EVBP Disconnected - Napa 6637 - FPR Shim
3" Down Pipe & CD - 203 Stat - 163 K Miles
  #5 (permalink)
Old 10-28-2009, 10:06 PM
kawa's Avatar
kawa kawa is online now
kawa has a good reputation on FTE. kawa has a good reputation on FTE.
Charge the batteries. They may seem strong but they may not be spinning the old bird fast enough. (Every little bit helps)
Rog
__________________
1997 Red 4X2 CC S/B-3" DP- No Kitty-6637
Cooling Sys. Filter-7 Gauges-6 Pos.PHP Chip
140V IDM-The "Cure"-CCV Mod w/Filter
1.0 Turbo-No EBP-Detroit Locker/Finned Cover
U. S. Gear Exhaust Brake-Ext. plug for Heater &
Cadillac Battery Water-On board Batt. Charger
  #6 (permalink)
Old 10-28-2009, 10:08 PM
kawa's Avatar
Jim, ya out typed me!
Rog
__________________
  #7 (permalink)
Old 10-28-2009, 10:37 PM
250turbo 250turbo is offline
250turbo is starting off with a positive reputation.
Jim & Rog ,another web foot!!
__________________
Kurt
'96 f250 h.d. p.s.d. super cab,long bed,e40d with cOOnhunterjoe trans mod.gutted ebpv,3x4 d.p. & 4" exhaust,gauges,ab injectors,tranny& inter coolers,ex. brake,ccv mod,130 gallons motion lotion,fs2500 by pass,certified j b welder
  #8 (permalink)
Old 10-30-2009, 01:02 AM
oldbird1965's Avatar
oldbird1965 oldbird1965 is offline
oldbird1965 is starting off with a positive reputation.
Rog, did you call me, my ears are burning?! Or, did you call me a PSD? I'm to old to spin over fast, just steady.
__________________
Glenn
96 2WD F250 auto, 6637, 7 guages, two trans coolers, 3 1/2" DP-4" exhaust, FS2500 oil bypass filter, 1" turbo housing, rad filter, 6 position TW, 99 IC, syn oil, Elec fuel pump, adrenaline HPOP, 140v IDM, rear disks, Baby Beans Injectors, 203*, 'the cure', dieselsite's trans filter & air bags.
  #9 (permalink)
Old 10-30-2009, 03:28 AM
kawa's Avatar
Quote:
Glenn, when I wrote that I almost put in par-emphasis (Not OldBird1965)
But than thought, Crap...let's see if he catches it. God Obs.
Rog
__________________
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
