Go Back   Ford Truck Enthusiasts Forums > Diesel > 1994.5 - 1997 7.3L Power Stroke Diesel
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1994.5 - 1997 7.3L Power Stroke Diesel SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 10-28-2009, 08:56 PM
blue66tang95f150 blue66tang95f150 is offline
blue66tang95f150 is starting off with a positive reputation.
Long trip and oil problems! Help!!
Ok, I let my brother take my truck and his family on a long 3 week travel trailer vacation. He is pulling a 7k trailer with it. Its a 95 powerstroke 5 speed 4x4 4.10 gears. Its all stock except for the resistor mod and cat delete. Well he is about 1000 miles from me, and it starts dumping oil out of the back of the motor somewhere. I know there are plugs on the back of the cylinders, but he doesnt think it is from that. What else can cause this? Any help and fast would be great. Thanks
Oh it just rolled over 200k on the odometer. Other than that it seems to run great. Although he said it has a bad vibration obove 2500 in third and fourth gears pulling grades. What kind of rpm can that motor take for pulling grades?
  #2 (permalink)
Old 10-29-2009, 10:37 AM
RRranch RRranch is offline
RRranch is starting off with a positive reputation.
Ny guess would be the HPOP leaking. It's the most common thing I"ve ever seen go. It is in the front but drains down the back of the engine and really messy when it does go.
__________________
93 F-250 2 wheel drive extended cab flatbed 7.3 IDI
94 F-350 4X4 crew cab long bed 7.3 Powerstroke
97 F-250 4X4 extended cab long bed 7.3 Powerstroke
07 New Holland TD95D farm tractor. Not quite a Ford anymore but still the right color at least!
  #3 (permalink)
Old 10-29-2009, 11:47 AM
He says the valley is clean. He says its coming from the passenger side, and is running off the starter.
  #4 (permalink)
Old 10-29-2009, 04:29 PM
foxracing0934's Avatar
foxracing0934 foxracing0934 is offline
1997 Ford F-350
foxracing0934 is starting off with a positive reputation.
Even though you mentioned it already I would double check the high pressure galley plug in the back of the head. The passenger side is the easy one to reach, all you have to do is pull off the DP and stick a 1/2" ratchet on it. when they go they leak like a siv, i.e. I lost a gallon on a 100 mile trip. I would also check the valve cover in the back to make sure that that is sealed up nice and tight. And while checking the galley plug check to see if it the turbo pedistal.
__________________
97 F-350 w/88,*** miles
DP Tuner, S.S. HPX Line, 4in MBRP, FPR shim, Dipricol Gauges (Tranny, EGT, Boost), 6637 Intake, Rosewood Stage II's, 6.0 I/C, 5" mitre cuts (6" soon though)
Soon to Come
New Tranny, H-11 studs, H2E, wheels and tires.
  #5 (permalink)
Old 10-29-2009, 10:00 PM
Yep that's what it was. He got a new plug from a near by ford dealer and changed it out this morning. So far so good. Took a sec to get the truck restarted though. Thats probably the most common leak cause of the down pipe right there cooking the orings.
  #6 (permalink)
Old 10-30-2009, 12:24 AM
oldbird1965's Avatar
oldbird1965 oldbird1965 is offline
oldbird1965 is starting off with a positive reputation.
Quote:
Never heard of that before. I stuffed a 3 1/2 down my firewall and now I'm wondering about that plug's oring. Foxracing, was your orings cooked?
__________________
Glenn
96 2WD F250 auto, 6637, 7 guages, two trans coolers, 3 1/2" DP-4" exhaust, FS2500 oil bypass filter, 1" turbo housing, rad filter, 6 position TW, 99 IC, syn oil, Elec fuel pump, adrenaline HPOP, 140v IDM, rear disks, Baby Beans Injectors, 203*, 'the cure', dieselsite's trans filter & air bags.
  #7 (permalink)
Old 10-30-2009, 03:27 AM
1997 Ford F-350
Nah, they actually had a problem with a specific run of the o-rings on some of the plugs and they blow out. Mine was torn into three pieces when I got mine out. So far I haven't had any issues with the drivers side head cuz that one is a PITA so I've heard.
__________________
Soon to Come
Tags
73 , long , powerstroke , preparing , trip
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
