Go Back   Ford Truck Enthusiasts Forums > Diesel > Pre-Power Stroke Diesel (7.3L IDI & 6.9L)
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 10-28-2009, 08:00 PM
johnboggs21's Avatar
johnboggs21 johnboggs21 is online now
johnboggs21 is starting off with a positive reputation.
Oil?
Anyone run any different oil in the winter vs. summer? I was gonna keep 15W-40 for winter.
__________________
1993 F-250HD 7.3L IDI E4OD
I'm gonna sign my name in that diesel smoke and let the ones that come along behind me choke!
  #2 (permalink)
Old 10-28-2009, 08:10 PM
87crewdually's Avatar
87crewdually 87crewdually is offline
87crewdually is starting off with a positive reputation.
15w40 all I ever use. Brand wise I went from high priced Rotella to Motorcraft diesel 15w40 from walmart.
__________________
87 CCD, 6.9 Banks Sidewinder turbo & ARP studs, fresh pump & injectors, str8 Pipe out the side, worked C-6, 4.56R&P & Laycock/GearVendors Overdrive
  #3 (permalink)
IDIDieselJohn's Avatar
IDIDieselJohn IDIDieselJohn is offline
IDIDieselJohn is starting off with a positive reputation.
They say it depends on how cold it gets where you are. I keep 15W-40 year round, even though I've seen temperatures go below -24*C (-10*F). When it's really cold I think you can run 10W-30, but someone can correct me on that.
__________________
Driving a Diesel adds a whole new meaning to smoking the competitor!
1990 Ford F250 4x4 5 speed 4.10 gears N/A 7.3 Diesel 568,000km/375,000miles, still on the orignal clutch!
1987 Ford E350 C6 Trans 3.55 gears N/A 6.9 Diesel Motorhome 26ft. weighin' 11,000 pounds and it's slow goin' up hills lol.
  #4 (permalink)
Old 10-28-2009, 08:16 PM
blueeyedfordguy's Avatar
blueeyedfordguy blueeyedfordguy is offline
blueeyedfordguy is starting off with a positive reputation.
Well, if you are running a 7.3 diesel, I would only consider 15w40. If you were in like minisoda or something like that where the temperatures were quite extreme then I would run 5w40 rottella T. Its synthetic too. But, only if you were in an extremely cold area. 15w40 should suit you well otherwise. no 10w30. That is gasoline motor oil. It will not withstand a diesel engine. Instead the sulfer will turn it into like paint thinner. Only use diesel engine oil in your diesel. But, I do use diesel engine oil in my truck.
  #5 (permalink)
Old 10-28-2009, 09:21 PM
Whoops, that's a typo, what I meant was 5W-40. lol my bad. But still I always run 15W-40 anyways.
__________________
  #6 (permalink)
Old 10-28-2009, 09:57 PM
6.9LF250BOY 6.9LF250BOY is offline
6.9LF250BOY is starting off with a positive reputation.
so any type of 15w-40? lol
  #7 (permalink)
Old 10-29-2009, 12:02 AM
Dave Sponaugle's Avatar
Dave Sponaugle Dave Sponaugle is online now
1986 Ford F-250
Dave Sponaugle is a name known to all Dave Sponaugle is a name known to all Dave Sponaugle is a name known to all Dave Sponaugle is a name known to all Dave Sponaugle is a name known to all Dave Sponaugle is a name known to all
When the IDI was produced the API service designation was SF/CD or SF/CE.
The part important here is the C, compression ignition.
Temps from 0 C or 32 F and higher, SAE 30
Temps -18 C or 0 F and up, SAE 15W-40
Temps 32 C or 90 F and below, SAE 10W-30
Ratings like CI-4 or CJ-4 and all those are for engines using high pressure oil to fire the injectors so it don't foam when released from the extremely high pressures in the injection system.
__________________
86 F250 HD 6.9 IDI ATS turbo "not exactly" stock 4x4 T19 BW1345 3.55LS both ends D60 front, 10.25" Sterling rear, ram air, dual stacks.
"I dig dirt"
FTE Guidelines
FTE Moderator IDI diesel forum
WV Chapter Member
  #8 (permalink)
Old 10-29-2009, 07:58 PM
yeah, as long as in the api oil doughnut, it has a "c" rating as well you can use it in diesels. Other wise you must resist all temptations to use it if it is just gasoline oil. You can run diesel engine oil in gas engines, but never run gas engine oil in a diesel. What I refer to as the api oil doughnut, is the circle that has info such as: 15w40 sm/cj-4, energy conserving. This is how you find oil that is rated for your needs.
  #9 (permalink)
Old 10-29-2009, 09:17 PM
1986 Ford F-250
If I were ever where my choice was gasoline (S for spark) rated oil or no oil, the gasoline oil will go in the engine.
But it will also get changed as soon as possible.
Gasoline rated oil do not have a detergent package that can handle the soot, or the suspension additives that keep the soot from being deposited in the engine.
__________________
"I dig dirt"
FTE Guidelines
WV Chapter Member
  #10 (permalink)
Old 10-30-2009, 12:42 AM
Knox's Avatar
Knox Knox is offline
Knox is starting off with a positive reputation.
5W-40 for 0 F and up
but what about if the temp is going to be around -25 to 0 F?
  #11 (permalink)
Old 10-31-2009, 12:18 PM
1986 Ford F-250
15W-40 for 0 F and up
For cold temps 5W-40, 10W-30 or synthetics do much better.
__________________
"I dig dirt"
FTE Guidelines
WV Chapter Member
Tags
73 , additives , diesels , idi , oil , synthetic
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
