2006 f250 code po211 and po611 any help would be great!!!!!!!!!!!!!! - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 10-28-2009, 05:33 PM
johull johull is offline
johull is starting off with a positive reputation.
sorry I meant code po299 and po611
I have a 2006 F-250 w/127,000 miles
started running bad a few days ago, it surges heavily going down the road you can hear the motor and then silence, more motor then silence (a very weird power surge)and also the turbo guage go up and down, and when it does, it honks out black smoke. It will barely do 65 mph. when I let off you can hear the turbo shatter like it has too much back pressure. I can hold it at one speed and it runs like crap!
the engine light came on and codes po299 and po611 came up, they are low boost and loss of FICM power or other internal FICM failure
I took out the VGT valve and its not stuck, new fuel filters,I cleaned the egr valve,
I need advice, the pcm is $1000, VGT $350, I dont want to just replace everything.
I have a nice truck and am afraid to drive it down the road if fear something is going to blow into peices
Old 10-29-2009, 07:22 AM
no one has any info?
Old 10-29-2009, 08:48 AM
senix's Avatar
senix senix is online now
senix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputation
I would post this down lower in the 6.0 forum. you will probably get some responses there.
Old 10-29-2009, 02:51 PM
jlmotox's Avatar
jlmotox jlmotox is offline
jlmotox is gaining momentum as a positive member of FTE.jlmotox is gaining momentum as a positive member of FTE.
not sure about the 299 code but I had a CEL and a 611 code and it was a bad FICM...truck ran fine and didn't notice anything.
x2 you will get more help in the 6.0 forum...
Old 10-31-2009, 12:13 AM
Bladesmith's Avatar
Bladesmith Bladesmith is offline
Bladesmith is starting off with a positive reputation.
Not sure on the 299 the 611 is most likely a bad FICM. PO611 is an internal fault. The 299 could be a product of that. Sounds like the truck is going into fail-safe mode(or limp mode) This cuts back engine performance to prevent further damage. Probably sucks fuel like pouring it from a bucket.
Old 10-31-2009, 09:04 AM
Quote:
I actually reposted this in the 6.0 forum and got some good replies.
I had the computer flashed and for the last 2 days it has been running fine. but it has been doing just that, one day its ok and the next badly. for a while it was doing it like clock work at an 1/8 of a tank it seemed, I dropped the tank and replaced the cheap rubber filter thinking it was sucking air. but it done it at a full tank after, just a coincidence I guess
oh and I cannot believe it doesnt have a baffle in the tank, I race r/c remote control gas cars and even they have baffles in the tanks, but I guess you should really be running it that low on fuel,taking a chance of running out
thanks for your thoughts,Jody
Old 11-08-2009, 07:52 AM
first time in my life, truck is fixed,cost me nothing!
I took my truck to the local Ford dealer and after they tested it, they said the FICM module was bad,as I expected. I got home and took it off hoping maybe the plug had corrosion or something b/c one side of the module puts out high voltage. it looked to be in perfect shape. My best guess would be that since it has 127,000 miles, the plug after getting hot so many time sending high voltage, simply lost continuity. they are just pin plugs, not what I would have put on the truck but what ever. I greased all three plugs and reinstalled the module and it has been perfect for over 200 miles. It runs 100% and all due to the plug. saved me $815.00 and an upset wife as well,now she has more money for shoes
I hope this helps someone else-Jo
Old 11-08-2009, 08:20 AM
king of bass's Avatar
king of bass king of bass is offline
king of bass is starting off with a positive reputation.
johull man im going to try that right now I have the same problem with mine 04 with 80,000 miles and i was going to the dealer on monday ficm 985.00 but im going out side and try what you did. I will let you guys know what happens
Old 11-08-2009, 09:38 AM
awesome, let me know if it helped
Old 11-08-2009, 01:18 PM
Johull it didn't help so I will let you know after I get back from the dealer tomorrow and get a new ficm installed
Old 11-08-2009, 04:47 PM
Quote:
it was worth a try, lmk
PO299 code twice now jaycenk 6.0L Power Stroke Diesel 37 05-21-2015 10:23 PM
PO341, PO487; slight hard start, Q's... wwblue05 1999 to 2016 Super Duty 12 02-12-2014 05:28 PM
Turbo farts 2006 6.0 L not much power. dmjm5 6.0L Power Stroke Diesel 11 09-01-2011 11:02 PM
2006 f-250 error codes po299 and po611 any help would be great!!!!!!!!!!!!!!!!!!!!!! johull 6.0L Power Stroke Diesel 16 11-08-2009 01:02 PM
SuperCharged Turbo Underboost, code PO299, means what? strf12 1999 to 2016 Super Duty 3 04-29-2009 04:59 PM
Tags
05, 2006, 60, black, blow, code, engine, f250, f550, fault, ford, fuel, po611, problem, smoke
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
