Go Back   Ford Truck Enthusiasts Forums > Small Chassis Trucks > Ranger & B-Series
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Ranger & B-Series All Ford Ranger and Mazda B-Series modelsSPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 10-28-2009, 06:18 PM
B 3000 B 3000 is offline
B 3000 is starting off with a positive reputation.
Over the top, or do you like it from the bottom
When removing the oil filter that is.
  #2 (permalink)
Old 10-28-2009, 07:22 PM
For those with a 3.0
  #3 (permalink)
Old 10-28-2009, 07:28 PM
cracked block cracked block is offline
cracked block is starting off with a positive reputation.
Bottom. But it's a tight squeeze getting the filter down past the heat shield.
  #4 (permalink)
Old 10-28-2009, 08:20 PM
pgw85706 pgw85706 is offline
pgw85706 is starting off with a positive reputation.
Top, easy to pull it through. Let it drain first then put your finger in the center hole to hold it as you pull. Don't do when it is hot.
__________________
__________________________________________________ __
'99 SCAB XLT 3.0L FFV M5OD 4x4 with off-road package
  #5 (permalink)
Old 10-28-2009, 09:32 PM
mfp4073 mfp4073 is offline
mfp4073 is gaining momentum as a positive member of FTE.
with my lift (stock 4x4) its very easy to do through the wheel well, just pull back the protective skirt
__________________
please do not take any of the above advice as that of an expert!
99 3.0 auto ext cab stepside 4x4
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
