Well, I got the yoke off, but now I have another question. The seal appears to have a metallic outer side and is behind a lip from the pinion flange. Is the proper procedure to just get a seal puller and pull out the seal from under the flange lip, or do you have to un-bolt the entire pinion flange to get at the seal? Thanks again.
-Miles.
