Go Back   Ford Truck Enthusiasts Forums > Diesel > 1994.5 - 1997 7.3L Power Stroke Diesel
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1994.5 - 1997 7.3L Power Stroke Diesel SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 10-28-2009, 04:33 PM
AzAtti2d AzAtti2d is offline
AzAtti2d is starting off with a positive reputation.
Fuel Supply Problem - Please Help
I have a 96 F250, 2WD that I am having fuel issues with. I might be able to work through this myself if I could find a diagram of the fuel line system somewhere... what lines go where, etc. Maybe you will be able to give me some ideas to keep me from lighting a match under this thing. When I purchased the truck a couple years ago, it had a homegrown veggie oil system installed on it. Basically the front tank was preheated and then the fuel(oil) was routed through a heat exchanger, elec. fuel pump, an add on oil filter and then back into the original system just behind the switching valve. When it worked it was wonderful. When it didn't it was pure frustration. So I removed all of the in-line stuff and just ran diesel in both tanks. I don't know if this has anything to do with my problem, but thought I should include that info up front.
So here is my problem... It started as a fuel filter issue. Fuel Filter light would illuminate, and about 3 miles later I'm dead on the side of the road. Replace the filter, drive for anywhere from 10 - 50 miles and repeat. When I take the filter out, the bowl would be empty and the filter would appear brand new, no sign of anything to clog it. I would change it anyway. So I drain both tanks, and then use fresh fuel. Now I no longer get the fuel filter light, or any other warning, it just loses power and dies, although occasionally when it is barely hanging on it will all of a sudden pick back up like it just got some good fuel and then quickly revert back to barely running again. When it finally dies, the only way to get it running again is to fill the filter bowl up with fuel and then start it. But it wont last long... maybe 5-8 minutes idling. When I open the filter housing, the bowl will be nearly full with the level just below the opening into the pressure regulator. I pulled the regulator yesterday and the screens were really gummed up so I cleaned it all out. still have the same issue. Also when I top off the fuel bowl and start it, the pressure at the schrader valve fitting reads about 20 In. Hg.(I know, but it was the only guage I had handy) which I'm not sure how that converts to PSI but I know it is a decent amount of pressure. After the truck idles for about 1 minute that pressure begins dropping to about 5 in/hg. a minute later and its at 1/2" hg and soon starts running rough and dies. I've even tried dropping the fuel line into a jerry can of clean fuel, tapped in where it goes into the switching valve, no difference. Not sure about the switching valve, but i can hear it "click" like it is switching when i flip the tank1/tank2 switch.
Any ideas? I'm beginning to think it might make for good target practice on my next trip to the desert...lo l
  #2 (permalink)
Old 10-28-2009, 04:45 PM
14psd's Avatar
14psd 14psd is offline
14psd is starting off with a positive reputation.
Azatti2d welcome to fte. Let me get this strait. You removed all of the veggie oil stuff, correct? Now you are back to all stock correct? Have you checked ALL of the lines that the veggie oil ran threw? That stuff will break down the rubber lines. Ask me how I know. I had to replace ALL of the rubber lines on my truck cuz I didn't switch them over to other kind of line. I forgot the name of the line. Anyway I blew a high pressure line and two of my small rubber lines failed. That's my 0.02. I hope that helps some.
__________________
Todd
__________________________________________________ _____________________________________
'95 F-350 daully, Super Cab, 200K+ miles, 2 wd, automatic, shimmed fpr, 3" down pipe, superchip, gauges boost, EGTs, trans, and volts, missing Kitty & muffler, , Homemade tymar set-up, HPX mod, BIG bore master cylinder, and air bags in the rear
  #3 (permalink)
Cuda_jim's Avatar
Cuda_jim Cuda_jim is offline
Adrenaline Junky
Cuda_jim has a great reputation on FTE. Cuda_jim has a great reputation on FTE. Cuda_jim has a great reputation on FTE. Cuda_jim has a great reputation on FTE.
Fuel pump is going bad.
BTW: 20 in. hg = 10 psi
You need 50 psi for it to run.
__________________
JIM
  #4 (permalink)
Old 10-28-2009, 04:46 PM
14psd's Avatar
thanks jim for that info I did not know that.
__________________
Todd
  #5 (permalink)
Old 10-28-2009, 05:50 PM
Fuel Pump?
I'm really hoping that the fuel pump going bad is not the case... I thought that mechanical pumps either work or they don't, but that they usually don't exhibit a "going bad" behavior. It wouldn't really surprise me though, as I replaced it about a year ago with a "life time warranty" pump from checker auto. Wouldn't be the first time those rebuilt suckers were garbage. It is just such a MF to replace... God I hate my life sometimes.
Can anyone tell me about the fuel routing on these trucks... from the tank through the system and back to the tank? Also anyone know about the fuel bowl elimination kits?
  #6 (permalink)
Old 10-28-2009, 08:30 PM
rodneywar's Avatar
rodneywar rodneywar is offline
rodneywar is starting off with a positive reputation.
get a new carter pump i just put one in It blew a hole in my bowl. My bowl had a weak spot from corrosion I put in a new one from ford the whole bowl assembly including everything for the bowl cost me 275. they originally quoted me 560. woot woot
__________________
Ronnie Warfield
1995 F 250 Turbo diesel reg cab 2wd
6637 mod, 3 inch dp, lost kitty, GPR mod, SD 120v idm, 2500 watt inverter
Maryland Chapter member
  #7 (permalink)
Old 10-28-2009, 09:28 PM
pjwoolw's Avatar
pjwoolw pjwoolw is offline
pjwoolw is gaining momentum as a positive member of FTE.
Here is a link to a pdf file that has a pretty good explanation.
Going to an electric system would be the the best thing to do but is costly. Dieselsite and Beans have kits. Or a DIY system.
If not you may need a new bowl and FPR if yours isn't rebuildable. Plus a new pump.
The latter is cheaper but you can look forward to doing it again down the road. But if you use good quality o rings and change filters regularly it may last quite a while. But if the pump is getting junk through it from the tanks it will likely fail fairly quickly.
SAE 30r9 is the rubber hose to use.
A good kit can be found here to replace the stock pump and good o rings for the bowl and FPR.
Good luck to you and welcome to the forum!
__________________
Pete in San Ramon
2005 F250 6.0 Lariat 4x4 CC Short bed (stock)
1997 F250 7.3 XLT 4X4 Reg. cab (stock)
1986 F250 6.9 XLT Gone but not forgotten
  #8 (permalink)
Old 10-29-2009, 07:03 AM
Cuda_jim's Avatar
Adrenaline Junky
The FP is a 2 stage pump. It sucks fuel from the tank(s) then pressurizes it for the injectors (60-80 psi).
Before you replace it be sure it can draw fuel through the lines. As Todd (14psd) already stated, the WVO system
might have damaged any of the rubber lines involved in the system.
Here's a fuel flow diagram:
__________________
JIM
  #9 (permalink)
Old 10-29-2009, 09:40 AM
Thanks!
Thanks alot for the help... especially the links and diagram... exactly what I needed(well, short of a free mechanic that is... anyone?... lol). If I'm not too giddy with excitement when I figure this out, I'll try to remember to let you all know what the results are. Thanks again!
  #10 (permalink)
Old 10-29-2009, 10:06 AM
helifixer's Avatar
helifixer helifixer is offline
Rest in Peace Jake
helifixer is a splendid one to behold helifixer is a splendid one to behold helifixer is a splendid one to behold helifixer is a splendid one to behold helifixer is a splendid one to behold helifixer is a splendid one to behold helifixer is a splendid one to behold
Where in Arizona are you?
if Northern Az I have a shop, if in the Valley I know a good one down there. keep us updated and if need be I can help hook you up locally.
on a side note drop by the Arizona chapter and say hi to the locos! uh I meant locals
__________________
They promise freedom, but they themselves are slaves of sin and corruption. For you are a slave to whatever controls you.
the little people who live behind my eyes and scream directly at my brain told me to tell you HELLO
Diamond K your complete automotive and truck repair center
  #11 (permalink)
Old 10-29-2009, 11:14 PM
I'm in the Valley of the Slum... lol... but I do appreciate the offer. That is very kind of you. I go north fairly often though, draggin the ol' 5th wheel camper up the mtn so you never know, I might run into you(figuratively speaking, of course) sometime.
It appears that the mystery has been solved. It was indeed the supply line from the tank. All of the fuel lines were in really bad shape from the WVO, so I replaced them and cleaned everything out, and it seems to be running pretty good. I'll take it out for a lengthy trial run tomorrow when there is daylight... just in case. What kinda gets my goat is that when I called the "friend" that I bought the truck from and mentioned the info about the WVO destroying the factory lines, his response was that he had heard that too but doesn't believe it to be true... "HELLO? Is there anyone home?"... sure would have been nice if he had passed that info on sooner... "Thanks, Buddy!"
So thank you to everyone again, and I will stop in here later tomorrow and let you know how my test drive went. Wish me luck!
  #12 (permalink)
Old 10-30-2009, 12:25 AM
kawa's Avatar
kawa kawa is offline
kawa has a good reputation on FTE. kawa has a good reputation on FTE.
I've been studying the fuel system diagram posted above and for the life of me.....where is the "Fuel Strainer" located? Is this in reference to a "Sock" on the fuel pick up stand pipe inside the fuel tank (s)?
Rog
__________________
1997 Red 4X2 CC S/B-3" DP- No Kitty-6637
Cooling Sys. Filter-7 Gauges-6 Pos.PHP Chip
140V IDM-The "Cure"-CCV Mod w/Filter
1.0 Turbo-No EBP-Detroit Locker/Finned Cover
U. S. Gear Exhaust Brake-Ext. plug for Heater &
Cadillac Battery Water-On board Batt. Charger
  #13 (permalink)
Old 10-30-2009, 12:58 AM
95_Dually's Avatar
95_Dually 95_Dually is online now
1995 Ford F-350
95_Dually is gaining momentum as a positive member of FTE. 95_Dually is gaining momentum as a positive member of FTE.
I thought the FPR was ahead of the injectors. The diagram shows it after the injectors. I guess I am stuck in the carburetor days, LOL.
__________________
Sam
Humble yourself and give thanks to GOD.
<>< Family of 7 saved by Grace <><
95 CC Dually 3inch downpipe no muffler/cat Edge Programmer, 6637 MOD, 140v
2000 Ranger 4X4 No MODS, yet!
  #14 (permalink)
Old 10-30-2009, 12:59 AM
Yep... that's my guess... thats the only possible explanation I could come up with
  #15 (permalink)
95_Dually's Avatar
1995 Ford F-350
Thank you for the diagram Jim. REPS SENT!
__________________
Sam
Tags
10 , 95 , back , dies , elmination , f150 , ford , fuel , kit , mechanical , min , powerstroke , pressure , pump , schrader , starts , straight , truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
