Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Computer Chips and Tuners
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Computer Chips and Tuners SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 10-28-2009, 12:47 PM
Sparky83's Avatar
Sparky83 Sparky83 is online now
Sparky83 has a very good reputation on FTE. Sparky83 has a very good reputation on FTE. Sparky83 has a very good reputation on FTE. Sparky83 has a very good reputation on FTE.
Question ODB I Tuner questions
Im just curious... i know with like the ODB II systems tuners can go through and turn things off.. like O2 Sensors, EGR sensors.. things like that.... But i was wondering if it was possible for it to be done on ODB I systems too??
like if i wanted to keep the stock tune or make it more "fuel efficient" could those sensors be turned off??
__________________
Shawn Official #17 Slackmaster!
The Republic was not established by cowards; and cowards will not preserve it ... This will remain the land of the free only so long as it is the home of the brave.Elmer Davis
  #2 (permalink)
Old 10-28-2009, 07:10 PM
Conanski's Avatar
Conanski Conanski is offline
1990 Ford F-150
Conanski has a great reputation on FTE. Conanski has a great reputation on FTE. Conanski has a great reputation on FTE. Conanski has a great reputation on FTE. Conanski has a great reputation on FTE.
If fuel efficiency is what you want you wont get there easily with a tuner, get a programmable wideband O2 sensor like the Innivate LC-1 to replace the stock sensor and set the narrowbad output to an A/F ratio leaner than 14.7:1
__________________
Paul O
1990 F150 4x4 XLT X-Cab 5.0, 3.55LS, Comp XE264HR-14, Flowtech LT's to 3" single, FRPP Mass Air Conversion, TweecerRT with BE, Innovate LC-1 wideband O2
  #3 (permalink)
Old 10-28-2009, 10:50 PM
Sparky83's Avatar
Quote:
not really was just to satisfy some of my curiosity... my current truck has an ODB I system on it and the EGR valve keeps tripping the sensor.. (little annoyed with it really) from what ive learned those Generation 1 EGR's like whats on my truck were prone to issues with carbon build up and constantly tripped the sensors.. so was more of curiosity of whether they could be turned off or not..
__________________
  #4 (permalink)
Old 10-28-2009, 11:26 PM
Conanski's Avatar
1990 Ford F-150
If your EGR is setting a code there's something wrong with it, it's as simple as that. The old EGR system used on early trucks can be eliminated without setting a code but if you have the DPFE version found on mid '90's trucks you're SOL. The TweecerRT I have can disable things like the EGR but it's a $500 tuner, you could probably fix your EGR problem for free if it's just a dirty valve or broken vacuum line. What code is it setting?
__________________
Paul O
  #5 (permalink)
Old 10-28-2009, 11:35 PM
Sparky83's Avatar
mines an 87... (and no not a ford ) but with inspections around here i cant delete the actual thing either
i replaced it back when i rebuilt the engine almost 3 yrs now.. it did it with the old EGR too (why it got replaced)... ill be sitting at a light and itll pop up.. start moving again and itll go out.. then theres other times itll pop back up while cruising for about 15 seconds and then go out again..
as far as i can tell the vacuum lines are good.. not hearing any hissing or anything like that from them...
ill have to get back to you on the code... i was gonna go pull it again since i cant remember the number it gave for it... but dads apparently loaned out the code reader we have to a guy at work.. might get it back tomorrow...
__________________
Tags
1990 , 23 , computer , f150 , ford , odb , truck , tuner , tuners
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
