Go Back   Ford Truck Enthusiasts Forums > Small Chassis Trucks > Explorer, Sport Trac, Mountaineer & Aviator
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Explorer, Sport Trac, Mountaineer & Aviator 1991-1994, 1995-2001, 2002-2005, 2006-2010 Ford ExplorerSPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 10-28-2009, 12:40 PM
reflex26 reflex26 is offline
reflex26 is starting off with a positive reputation.
Is my rear axle a LS
Hi, I have a 96 explorer xlt and the door sticker says it has a D4 axle. I just got it so I don't know much about this particular vehicle.I jacked the rear up so the rear tires were off the ground and put it in neutral. I rotated one tire in one direction and the other side didn't rotate in either direction,It didn't move at all. This has me worried because I read a thread somewhere that the check is to rotate one tire in one direction and the other side rotates in the same direction it is LS and if the other side rotates in the opposite direction it is open,but this does neither which confuses me.Can anyone help me?Thanks.
  #2 (permalink)
Old 10-28-2009, 03:06 PM
ncranchero's Avatar
ncranchero ncranchero is offline
ncranchero is gaining momentum as a positive member of FTE.
D4 is limited slip, 3.73 ratio.
Limited slip, both wheels should turn in the same direction. Open, one in one direction the other opposite.
__________________
________________________________
"Information is valued and appreciated...Attitude is not!"
Steve,
'98 F150 Super Cab 4x4 SOLD, '99 Mustang 35th,
'02 Sport Trac 4x4, '01 Sport Trac Job 2 donor vehicle
'08 E250 Super Duty, No more Ranchero
  #3 (permalink)
Old 10-28-2009, 03:28 PM
NumberDummy's Avatar
NumberDummy NumberDummy is offline
Ford Parts Guru
NumberDummy has a superb reputation NumberDummy has a superb reputation NumberDummy has a superb reputation NumberDummy has a superb reputation NumberDummy has a superb reputation NumberDummy has a superb reputation NumberDummy has a superb reputation NumberDummy has a superb reputation NumberDummy has a superb reputation NumberDummy has a superb reputation NumberDummy has a superb reputation
1959 thru today:
If the AXLE code on the Certification Label (or Warranty Plate) begins with a letter: Limited Slip.
If the AXLE code begins with a number: No Limited Slip.
Some Limited Slips use steel and lined plates. The number of each varies depending on the axle.
For example, some have 6 steel plates & 5 lined plates.
If the lining on those plates is worn down to nothing, your Limited Slip...no longer works.
__________________
Bill / Retired Ford Partsman (1962/97) / SoCal Chapter Member.
Part Number Research: Trucks: 1928/2000 // Cars: 1928/79.
1934 Packard V12 Convertible Victoria // 2008 Fusion S // 2008 Edge SEL.
  #4 (permalink)
Old 10-28-2009, 03:49 PM
Thanks for the info.If the lining on the plates is worn will that cause the other wheel to not turn in either direction? I understand that at least the axle worked before I bought the truck. I bought it from my son and he drove it until the fuel pump went and he sold it to me.
  #5 (permalink)
Old 10-28-2009, 05:19 PM
mrshorty mrshorty is offline
mrshorty is starting off with a positive reputation.
Quote:
1959 thru today:
Assuming that the current axle is the same one the truck left the factory with. If the axle has been rebuilt/replaced, who knows what's there. Also, as noted, when the clutches wear out, it becomes an open differential.
maybe. The standard test for these is to measure how much torque it takes to rotate one wheel (transmission in N) while the other stays stationary. If memory serves, spec is 20 ft lbs. Where you had both wheels off the ground (assuming no issues with the brakes), it probably took next to no effort to spin that one wheel while the other stayed stationary. This almost certainly suggests that those clutches are worn out.
__________________
'87 Bronco II XLT 4x4 & '92 Explorer XLT 4x4 & '98 Chev Suburban K1500 SLT 4x4
  #6 (permalink)
Old 11-01-2009, 06:23 AM
Thanks again for the advise.I'll check things out this weekend,weather permitting.I think I'll really enjoy this truck.I plan on fixing it up to be a nice ride.
Tags
2004 , axle , certification , code , d4 , differential , explorer , f150 , find , label , limited , ls , plate , ratio , slip
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
