Go Back   Ford Truck Enthusiasts Forums > Small Chassis Trucks > Escape and Escape Hybrid
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 10-28-2009, 12:27 PM
Escape055 Escape055 is offline
Escape055 is starting off with a positive reputation.
Rear window washer
This is a goofy question but our rear window washer has never worked. I am assuming it pulls from the same tank as the front washer? Is this correct or is there another tank I have not found. I can here the motor come on when I turn on the rear window washer so I might have a hose off somewhere. Just wanted to make sure it did pull form the front tank.
Thanks!
  #2 (permalink)
Old 10-28-2009, 01:14 PM
Nitramjr's Avatar
Nitramjr Nitramjr is offline
Exiled from the club.
Nitramjr is a splendid one to behold Nitramjr is a splendid one to behold Nitramjr is a splendid one to behold Nitramjr is a splendid one to behold Nitramjr is a splendid one to behold Nitramjr is a splendid one to behold Nitramjr is a splendid one to behold
It does use the same tank as the front windshield. Never had any problems with mine so I haven't really thought about how it works beyond that. Good luck.
__________________
Ray
'97 F250 XL, 5.8L, '05 Escape Hybrid, '06 Escape Hybrid
  #3 (permalink)
Old 10-28-2009, 02:03 PM
Thank you!!
  #4 (permalink)
Old 10-29-2009, 10:37 PM
scott91370 scott91370 is offline
scott91370 is starting off with a positive reputation.
Unplug the hose from the washer bottle and pull the switch. This is an easy way to see if it is the pump- even if you can hear it it doesn't mean it's working. If it does then hook that end up and unhook the end from the sprayer nozzle to see if it will come out there. If so then the nozzle has the clog.
  #5 (permalink)
Old 11-14-2009, 10:35 AM
hotroddually's Avatar
hotroddually hotroddually is offline
1974 Ford F-350
My Garage
hotroddually is gaining momentum as a positive member of FTE. hotroddually is gaining momentum as a positive member of FTE.
i could be wrong, but on our 2008 escape i was told there was a separate fluid reservoir for the back wiper located in the back. i can't confirm this yet, as i have not had to fill it up. the truck is not at home right now,but i'm going to look tonight.
__________________
74 f350 4x4 dually 428scj,-HOOF BEATS ARE LOUDER THAN HEARTBEATS!
2001 ranger xlt supercab 4x4
2008 ford escape xlt
2006 harley davidson softail fxst
Tags
escape , ford , rear , trucks , washer , window
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
