Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W)
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 10-28-2009, 11:10 AM
1984F15016 1984F15016 is offline
1984F15016 is starting off with a positive reputation.
5.0 HO mustang fuel pump in a 5.0 bronco?
I have a 95 bronco with a 5.0 that has a weak fuel pump, i had an 89 mustang with the HO 5.0 that i put a new fuel pump in and crashed a month later. Can i put the mustang fuel pump onto the sending unit of my bronco and install in the truck?
__________________
1984 2wd F-150
300ci I6
4 speed
Under Restoration
  #2 (permalink)
Old 10-28-2009, 11:17 AM
Conanski's Avatar
Conanski Conanski is offline
1990 Ford F-150
Conanski has a great reputation on FTE. Conanski has a great reputation on FTE. Conanski has a great reputation on FTE. Conanski has a great reputation on FTE. Conanski has a great reputation on FTE.
Your bronco fuel pickup assembly has a plastic resovoir around the pump, so the Mustang pump will not fit inside it.. especially if it's an aftermarket high volume pump, they's longer.
__________________
Paul O
1990 F150 4x4 XLT X-Cab 5.0, 3.55LS, Comp XE264HR-14, Flowtech LT's to 3" single, FRPP Mass Air Conversion, TweecerRT with BE, Innovate LC-1 wideband O2
  #3 (permalink)
Old 10-28-2009, 01:49 PM
naw its just a stock replacement pump, oh well just thought id ask. Ill just get a new pick up/pump
__________________
1984 2wd F-150
300ci I6
4 speed
Under Restoration
  #4 (permalink)
Old 10-28-2009, 06:40 PM
Kemicalburns's Avatar
Kemicalburns Kemicalburns is offline
Kemicalburns has a good reputation on FTE. Kemicalburns has a good reputation on FTE.
go thru ford regarding that pump/pick-up. best quality and price isnt much more then the knock off brands.
__________________
94 XLT 5.8/E4OD/Warn HS9500I
6"ProComp Stage II 35x12.5x15 BFG MT's
4.88 gears/Aussie Front/rear open
JBA shorty, Custom Y pipe,3" exhaust
http://www.supermotors.org/registry/...il.php?id=4158
Tags
300ci , 50 , 84 , 89 , bronco , foxbody , fuel , ho , i6 , install , mustang , performance , pump , replacement , upgrades
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
