Go Back   Ford Truck Enthusiasts Forums > Diesel > 1994.5 - 1997 7.3L Power Stroke Diesel
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1994.5 - 1997 7.3L Power Stroke Diesel SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 10-28-2009, 10:50 AM
SWMO F-350 SWMO F-350 is online now
SWMO F-350 is starting off with a positive reputation.
Is This A Good Buy 96 F-350 For $3350
1996 LETS TRY AGAIN F350 POWERSTROKE SUPER DUTY W/ TURBO
Owner says its real clean and will pull anything.Has 220,000 miles and the motor and tranny have never had any major work.Has a slight miss between 40-50 mph so may need new injectors?
I'm ready to get rid of my underpowered 1991 F-350 IDI that gets 7 mpg at 45-50 mph pulling a 25 foot gooseneck.
  #2 (permalink)
Old 10-28-2009, 11:19 AM
14psd's Avatar
14psd 14psd is offline
14psd is starting off with a positive reputation.
ok I did a kbb on it and here is the link.
1996 Ford F350 - Private Party Pricing Report - Kelley Blue Book
For what it's worth (kbb that is). Now from personal experience as you can see I have just over 200K on my truck. I just dropped $3200 on my trans. I have it built! You can expect to have to do something soon if plan on doin alot of heavy haulin'. The price seems good in my opinion. See if he has the maintenance records that will tell you ALOT about the truck. Find out as much as possible from the seller as you can. If you go to drive it see if you can try and start it on a cool day below 45* to check gps and gpr thats any easy kicker for price for you. Well thats my 0.02 . Good luck.
__________________
Todd
__________________________________________________ _____________________________________
'95 F-350 daully, Super Cab, 200K+ miles, 2 wd, automatic, shimmed fpr, 3" down pipe, superchip, gauges boost, EGTs, trans, and volts, missing Kitty & muffler, , Homemade tymar set-up, HPX mod, BIG bore master cylinder, and air bags in the rear
  #3 (permalink)
Old 10-28-2009, 11:42 AM
Brown Falcon's Avatar
Brown Falcon Brown Falcon is offline
1995 Ford F-350
My Garage
Brown Falcon is starting off with a positive reputation.
Good price. If it's an auto it will probably need a transmission soon if it's still the stock one. I'd check maintenance records like 14PSD said.
That miss could be a lot of things. Low fuel pressure, something electronic... probably not injectors.
__________________
Brownie, Ooh-Rah! USMC Member of the NRA!
'95 F350 CC 4x2 - SRW Swap, E40D, PHP 6 Pos. Chip, 6637 mod, 3" D.P., Lost Kitty, 140v IDM, HPX Mod, FPR Shim (65 psi), T.C. switch, 3.55 gears
'88 F350 CC 4x4 - lots of dents, faded paint, old 7.3 IDI in pieces
  #4 (permalink)
Old 10-28-2009, 01:47 PM
foxracing0934's Avatar
foxracing0934 foxracing0934 is offline
1997 Ford F-350
foxracing0934 is starting off with a positive reputation.
I don't know how willing you are to travel to get the truck but someone else just posted a real clean truck, same as that one just white and it's a standard so you won't have to worry about the tranny. And it's got like 147,000 on it or something close to that. It was in SC I think and it was like 4,800
__________________
97 F-350 w/88,*** miles
DP Tuner, S.S. HPX Line, 4in MBRP, FPR shim, Dipricol Gauges (Tranny, EGT, Boost), 6637 Intake, Rosewood Stage II's, 6.0 I/C, 5" mitre cuts (6" soon though)
Soon to Come
New Tranny, H-11 studs, H2E, wheels and tires.
  #5 (permalink)
Old 10-29-2009, 01:20 AM
Thanks everyone.I decided to pass on this one due to the high mileage.
  #6 (permalink)
Old 10-29-2009, 03:14 AM
kawa's Avatar
kawa kawa is online now
kawa has a good reputation on FTE. kawa has a good reputation on FTE.
For what it's worth....220K is not high mileage for a PSD. That's not even half way to the recommended overhaul mileage.
Rog
__________________
1997 Red 4X2 CC S/B-3" DP- No Kitty-6637
Cooling Sys. Filter-7 Gauges-6 Pos.PHP Chip
140V IDM-The "Cure"-CCV Mod w/Filter
1.0 Turbo-No EBP-Detroit Locker/Finned Cover
U. S. Gear Exhaust Brake-Ext. plug for Heater &
Cadillac Battery Water-On board Batt. Charger
  #7 (permalink)
Old 10-29-2009, 04:48 AM
Iallwork Iallwork is offline
Iallwork is starting off with a positive reputation.
manual trans: I've heard of somepeople pulling their fuse on manual trans. stops the OD. Doesn't work on auto. Beware! never did it myself. auto
  #8 (permalink)
Old 10-29-2009, 04:54 AM
Get a good torque converter! And a good tranny guy. you'll be OK with a shift kit on a slitely modified truck with a shift kit. It should shift hard.
  #9 (permalink)
Old 10-29-2009, 05:32 AM
drivembig's Avatar
drivembig drivembig is offline
drivembig is starting off with a positive reputation.
If the truck is clean, have it checked out by a good mechanic. It may cost you 100 bucks or so, but for that price if it checks out ok it would be worth it. It says "heavy duty torque converter shift kit". If it's had a new torque converter and a shift kit installed early in it's life, chances are that the tranny should be in better condition than one that is stock.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
