Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > Expedition & Navigator
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 10-28-2009, 10:20 AM
mitchg mitchg is offline
mitchg is starting off with a positive reputation.
looking to buy 03 or 04
Hello, I'm new here, and I have a couple of questions. My wife and I are looking for a new (to us) suv. We have found an 03, and an 04 expedition, both eddie baur. Both have 108-110 miles, and are priced in the upper $13. Is this a deal? What issues should I look for. Which year is better, if at all?
  #2 (permalink)
Old 10-28-2009, 10:37 AM
alwaysfords41 alwaysfords41 is offline
alwaysfords41 is starting off with a positive reputation.
I can't speak to the deal, take a look around and see where prices are. Check out the papers, ebay, etc. If the prices are similar get the newer one. I've got one of each and they are pretty much the same vehicle, the '03 was the first year for the new body style and had a number of problems in early builds. There is a letter designation in the VIN that tells you the series of the build, A is the first. Mine is a C (if memory serves me, June '03) and has been relatively problem free. The big issues are head machining problems leading to oil leaks (supposedly fixed by '03 but mine had the issue) and LSD clutch packs failing. You should be able to deal pretty well on these, they are getting old.
__________________
2003 Expedition EB 5.4, 4x4 now @ 121k miles on our 6th anniversary
2004 Expedition EB Premium 5.4, 4x4 now @ 64k miles
Gone but not forgotten;
1995 Bronco XLT 5.0, 4x4, 15k miles
1996 Explorer XLT 5.0, AWD, 75k miles
1999 Expedition EB 5.4, 4x4, 95k miles
  #3 (permalink)
Old 10-28-2009, 11:01 AM
03 vin # 1FMFU18L63LA60429
does that A mean 1st series? should I avoid this one? I have not looked at either one yet, maybe this weekend. They are at the same dealer.
  #4 (permalink)
Old 10-28-2009, 11:20 AM
That is an A code. Depending on mileage the gremlins could be all gone. Ask for service records. Also on the head machining problem, it winds up resulting in an oil leak that is in many cases not detectable because the oil drips on the exhaust manifiold and burns. The engine bay can be completely dry and there will be no drips on the floor. Only way to find it is by the dipstick over time. For what it's worth my 04 is cheaper to insure than the 03, not sure why but I'm guessing it may be because the 04 has stabilitrac. Exact same coverage from the same compnay.
__________________
  #5 (permalink)
Old 10-28-2009, 12:55 PM
What kind of mpg can I expect from a 5.4, w/ 4x4?
  #6 (permalink)
Old 10-28-2009, 12:58 PM
12-15, although I'm sure others will tell you they get 20. I've had this motor three times now, it's never been anything different.
__________________
  #7 (permalink)
Old 10-28-2009, 02:45 PM
03 has been sold, the dealer is emailing me as many details/pic that they have.
  #8 (permalink)
Old 11-01-2009, 12:02 AM
fiveohpoepoe's Avatar
fiveohpoepoe fiveohpoepoe is offline
fiveohpoepoe is starting off with a positive reputation.
For mid $14k range you should be able to get a nice 04 with 55-75k miles,loaded.At least we did about 7 months ago. Where are you located? I agree with the above post about mpg. I have owned 3 98,s with the 4.6 and NEVER saw anything above 17 mpg on the hwy driving like Ms. Daisy. My current 99 with 5.4, 15.3 ONE time, hwy cruising with little to no fluxuation in speed. Our 04 with the 5.4 has seen mid 15,s on trips. I just dont see how anyone can get anything more than that, much less 20.
  #9 (permalink)
Old 11-01-2009, 09:18 AM
apgarassoc apgarassoc is offline
apgarassoc is starting off with a positive reputation.
Get a late-production 2004
I have a late production 2004 and have had good luck - 130K and no major problems. Biggest repair was front bearing hubs (very easy to do yourself - no puller required, just a 18 mm socket). If I keep the fuel filter clean, my mileage runs about 16 mpg without too much babying of the throttle. In the winter, oxygenated fuels knocks it down to 14.5 mpg. You can use a tuner to do better (lean out the programmed fuel mix) but I haven't bothered - it can result in higher exhaust temps which may result in other damage (catylitic converter, for instance). If you check the TSB database, you will see some 2004 issues in the early production runs - like pads and thens rotors (after they changed the pads). So find a May or June '04 build if you can.
  #10 (permalink)
Old 11-02-2009, 09:40 AM
We found an 05 EB 4x4 5.4 w/ 70k, and some hail damage, for $14k, that we are going to look at next weekend.
Are there any problem areas that I need to look for?
Located in central Ks.
  #11 (permalink)
Old 11-02-2009, 10:25 AM
04markIII's Avatar
04markIII 04markIII is offline
04markIII is starting off with a positive reputation.
05 switched to 3v engines. more power and tq, but drive-by-wire. they do have issues with the spark plugs breaking off in the head when trying to chenge them. and still retain the lsd clutch problem. overall 03-06 is a great model. i have an 03 (build code c).
__________________
2003 Ford Expedition: 5.4L, harley supercharger, 6lb lower pully, c&l plenum, k&n cai awaiting install, LFP SBTB, FTSP, Magnaflow 3" catback, 2006 F150 20's, 2800 stall converter, Hawk brake pads, Drilled rotors, Eclipse AVN-5510, white face gauges, cobalt c2 boost gauge, 339 rwhp, 440 rwtq(dynoed with oem 17's)
  #12 (permalink)
Old 11-02-2009, 11:13 AM
dirtmonkey11's Avatar
dirtmonkey11 dirtmonkey11 is offline
dirtmonkey11 is starting off with a positive reputation.
The price seems a little steep to me but I could be wrong. I have a 2000 Expedition XLT with 84,000 miles and all the options and I got it for $5,000 but that was because I bought it from family. I was looking around before I bought that truck and saw that a similar truck to mine were going for about $6-7 at most dealers. If you could I would try to buy if from a private seller if you have the money in had. I would shop around a little more because when winter comes closer the vehicle prices start to drop a little. All in all the deal is ok.
  #13 (permalink)
Old 11-02-2009, 11:18 AM
I agree, 04 EB 4x4 w/ 110k @ 13900 is about 1000-1500 high. Hopefully we can talk them down.
We are leaning toward an 05 EB 4x4 70k with hail damage for 13900, but we will need to look at it 1st to see the extent of damage.
What is lsd clutch pack?
What are spark plugs? lol j/k
I'm used to 7.3 Powerstrokes, manual tranny's, and manual 4x4's. All this electric/automatic stuff has me baffled.
  #14 (permalink)
Old 11-02-2009, 11:40 AM
LSD clutch pack - Limited Slip Differential clutches. They bind and grind as they age. If you turn a tight corner you will feel them catching. For some reason Ford had trouble with this series of LSD's, generally they don't ever go bad with proper fluid changes. For the fix -sometimes it is as easy a fluid change, others require a rebuild.
__________________
  #15 (permalink)
Old 11-02-2009, 11:47 AM
are the lsd's in the rear end, and are the difficult/expensive to fix?
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
