Go Back   Ford Truck Enthusiasts Forums > Diesel > 2003 - 2007 6.0L Power Stroke Diesel
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
2003 - 2007 6.0L Power Stroke Diesel SPONSORED BY:
Is F-150 Still King?
  #16 (permalink)
Old 10-29-2009, 09:18 PM
Headviking's Avatar
Headviking Headviking is offline
Headviking is starting off with a positive reputation.
So from what I understand, using a tuner without the ARP studs will shorten the life span of my OEM head bolts.
__________________
07 F250 6.0L PSD Lariat
Dieselsite Coolant Filter
Bilstein Shocks/Rough Country Steering Stabilizer
Fumoto Oil Drain Valve
24" Wiper Blades
  #17 (permalink)
Old 10-29-2009, 09:29 PM
tex25025's Avatar
tex25025 tex25025 is offline
tex25025 has a great reputation on FTE. tex25025 has a great reputation on FTE. tex25025 has a great reputation on FTE. tex25025 has a great reputation on FTE. tex25025 has a great reputation on FTE.
Quote:
This is going to be nit-pickin here, but using a tuner doesn't mean that it will shorten the life span of the stock bolts, but using a tuner can shorten the life of the stock bolts.
There are alot of different variables that come into play here. Were the bolts installed correctly either at the factory or at a later time rather they were replaced with stock bolts or a/m studs, what type of tunes are you using(canned or custom(if custom how is the power achieved?), not necessarily tow v. street v. race), what type of driving style does the driver have?
Now, I'm not saying tuners, rather custom or canned, can't cause problems, they can, but they can also make existing problems known that people may or may not have known that they had. This is where I think tuners have the bad rep. There are users on this board that believe, you run a tuner, you're going to blow the bolts; you may blow them, but you may not, they phrase it however, as that it is known that you will blow them.
__________________
'06 6.0L Turbo Diesel King Ranch DRW 4.30 Gears
Spartan Stage 1 Towing Injectors
Spartan 64mm Non-VGT Turbo
Fluidampner
Headstuds
Beta Spartan Phalanx
Fuel Regulated Return
FASS 150/180
Suncoast Heavy Duty Torqshift Rebuild
5" Straight-Piped MBRP Exhaust
Tranny, EGT, Boost, and Fuel PSI C2 Gauges
Water Temp, Oil PSI, Volts Antique Beige Gauges
  #18 (permalink)
Old 10-29-2009, 09:31 PM
jmaskew's Avatar
jmaskew jmaskew is offline
jmaskew is gaining momentum as a positive member of FTE. jmaskew is gaining momentum as a positive member of FTE.
It's very possible if the OEM bolts weren't torqued right at the factory.
__________________
^Camping at ZION NP, Utah^
Jonathan
2004 F250 PSD SB King Ranch 4x4:Build Date: 01/23/2004
Dieselsite Coolant Bypass Filter, High Idle Mod
Fumoto Oil Drain Valve, Harpoon Mod, Zoodad
Isspro 40 PSI Boost, Water Temp, Oil Temp and Trans Temp
  #19 (permalink)
Old 10-29-2009, 10:16 PM
ljutic ss's Avatar
ljutic ss ljutic ss is online now
2003 Ford F-250
ljutic ss is gaining momentum as a positive member of FTE.
If anybody wants an idea of how long the HG's will last while doing a lot of towing. I have a friend who has a 2003 Excursion (Oct. 2002 build 6.0) that has just over 150,000 and tows a boat and trailer (10,000 LB.) from Phila. to the Jersey shore every weekend weather permitting for the past 7 years. No parts except a ICP replacement when it was new ever failed. Original turbo, injectors, and ball joints. This truck was never messed with, all factory. My ball joints (lowers) only lasted 102,000
  #20 (permalink)
Old 10-29-2009, 11:54 PM
prem1 prem1 is offline
prem1 is starting off with a positive reputation.
I have 220K on my 04, I've been running SCT street tune for probably the last 80K. I didn't have any gauges before the SCT, I pulled a toy hauler around about as hard as I could, I'm a little better about it now that I have gauges. I don't want to say anything to jinx myself but I'm surprised I don't have more probs. I've got something going on that sooner or later I expect to get bad, whatever it is.
I might need something expensive right now, I'm just waiting to see if I can stretch it out until I'm ready for a new truck. I've had some puking for 100K miles, tea kettle noise but new cap stopped that, I get a little bit of white residue and I can hear it hissing after shutting down but coolant level doesn't drop and I have no other noticeable symptoms. I had the no heat at idle thing for a while but I flushed the heater core with a product we use to clean water cooled refrigeration condensers and it's roasting now, ran it through the block and I'm getting some crud out to say the least so I finally got a coolant filter this week.
Tags
2006 , 60 , 60l , bolts , diesel , f250 , ford , gasket , gaskets , head , last , leaking , long , stock , tuner
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
