Go Back   Ford Truck Enthusiasts Forums > Bronco > Big Bronco (1978 - 1996)
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Big Bronco (1978 - 1996) SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 10-28-2009, 12:17 AM
o1d_dude o1d_dude is offline
o1d_dude is starting off with a positive reputation.
Intermittent Problem: Won't Start
I'm having an intermittent problem with my 1994 351 Bronco that is occurring more frequently of late.
When I go to start the truck, it turns over and coughs once. Next attempt to start, the motor just cranks with no hint of a start. Next day or only hours later, I'll go out and it starts on the first crank. Due to this unreliability, I've not been driving it.
My first thought is to check the fuel pumps, filter, distributor cap, ignition wiring, etc. Beyond that I'm thinking I need an OBD meter to read the codes the system may be throwing.
The Bronco has 185K miles, has a new computer, distributor, cables, ignitors, water pump, radiator, and hoses all within the last two years.
Any hints or suggestions?
Thanks, Kit
  #2 (permalink)
Old 10-28-2009, 12:19 AM
Whoa. Not sure why there are no paragraphs in my post above. Hope you can read it.
  #3 (permalink)
Old 10-28-2009, 01:03 AM
greystreak92's Avatar
greystreak92 greystreak92 is offline
1992 Ford Bronco
greystreak92 is gaining momentum as a positive member of FTE. greystreak92 is gaining momentum as a positive member of FTE.
First off, welcome to FTE and the Big Bronco Forum.
My first suggestion would be to check electrical connections. I know, I know, "but it tries to start sometimes". But if the weather where you are is anything like it is here, its so freakin humid that flash-corrosion occurs in hours rather than days or weeks. Enough in the right (or wrong as the case may be) places can let it start but vibrations will work things loose in a hurry.
If that yields nothing tangible and the problem persists, run a KOEO test first and see what the computer says is ailing it. If there are no codes present or you get a 11 or 111 then move on to a KOER test... the tricky part with the KOER is getting it started and keeping it running long enough to get to operating temp BEFORE you run the test.
On a side note, unless your '94 happens to be OBDII (which is rare if I recall), you don't need a decoding device any more complicated than a paperclip. Check this out..
__________________
Only stupid question is the one you don't ask.
1993 Bronco XLT 5.0, E4OD (at the moment)
1992 F-150 XLT 4.9, M5 (at the moment)
UPDATED! Big Bronco FAQ's
  #4 (permalink)
Old 11-01-2009, 09:51 AM
BULLETPROOF4.9's Avatar
BULLETPROOF4.9 BULLETPROOF4.9 is offline
BULLETPROOF4.9 is starting off with a positive reputation.
Don't know if this helps, but I had the same issue with one of mine, and it turned out to be the pickup coil on the distributor.
Tags
1992 , bronco , ford , fuel , intermittent , pump , start , wont
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
