Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W)
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 10-27-2009, 11:49 PM
chrisbrown67 chrisbrown67 is offline
chrisbrown67 is starting off with a positive reputation.
92 f-150 302 build need some advise/direction
I recentlt bought a nice 92 f-150 302 4x4 ex cab.Motor works good but has bad crack in exh. manifold.i want to build thisengine to 325-350 hp.want it to handle the occasional mud hole.I just put 33 hercules mud tires on
1.i just bought some hedman long tube headers and a 2 1/2 pipe kit with no cats and two c.b. glasspacks.
2.I have a f303 cam in my garage barely used
what parts should i be looking at?Ive been told not to run that cam without switching from speed density to mass air first
if i dont switch what cam/heads(cant find gt40p's)/intake should i use with the exhaust
if i use the cam is it now going to NOT be so much of a budjet build or does it work out the same in the end.
would it be easier to i find an 87-93 mustang motor complete with computer?i would prefer not to do that.
Any assistance would be GREATLY APRECIATED!
I dont know what to do but i am ready to roll on something.
  #2 (permalink)
Old 10-28-2009, 12:05 AM
DLP Performance DLP Performance is offline
DLP Performance is starting off with a positive reputation.
Get some flat top pistons & a mild cam. If you get too wild, you'll need a special tune. There's alot more going through that ECM than just the engine controls. That's just my opinion.
  #3 (permalink)
Old 10-28-2009, 07:14 AM
lew52's Avatar
lew52 lew52 is online now
lew52 is gaining momentum as a positive member of FTE.
The long tubes & exhaust will help alot , i don't think you can use the f cam with out mass air , check craigs list for some gt-40 heads , what gears are you running with the 33s.....
  #4 (permalink)
Old 10-28-2009, 07:33 AM
Quote:
Ive been told the same about the cam,Maybe someone can confirm for us that the truck wont like that cam.
Im in Moncton New Brunswick Canada.We dont have C.L. but we do have KIJIJI and i monitor it like a mad scientist
  #5 (permalink)
Old 10-28-2009, 07:35 AM
Stock gearing
  #6 (permalink)
Old 10-28-2009, 09:22 AM
Conanski's Avatar
Conanski Conanski is offline
1990 Ford F-150
Conanski has a great reputation on FTE. Conanski has a great reputation on FTE. Conanski has a great reputation on FTE. Conanski has a great reputation on FTE. Conanski has a great reputation on FTE.
Chris these trucks came with a wild range of gearing options so "stock gearing" literally means nothing. It really doesn't matter what gears are in it now though because you need 4.56's for those tires and that ratio was never offered. So start with that before you do anything else because mods to the 302 will make the powerband even peakier than it is now so you need to get the truck setup to let the engine spool. Your transmission will last much longer too. None of the Ford alphabet cams are compatable with the truck SD EFI system so it needs to be conversion to mass air first. Once there you could use the F cam but it's all wrong for a heavy truck IMO there are much better options out there that will produce a wider powerband.
__________________
Paul O
1990 F150 4x4 XLT X-Cab 5.0, 3.55LS, Comp XE264HR-14, Flowtech LT's to 3" single, FRPP Mass Air Conversion, TweecerRT with BE, Innovate LC-1 wideband O2
  #7 (permalink)
Old 10-28-2009, 10:53 AM
Awe, just put a turbo or supercharger on it!
  #8 (permalink)
Old 10-28-2009, 01:04 PM
daveengelson's Avatar
daveengelson daveengelson is offline
daveengelson is gaining momentum as a positive member of FTE. daveengelson is gaining momentum as a positive member of FTE.
Came across couple articles on subject. Also recall reading article in CarCraft, not sure what issue; if interested, may be able to locate in their online 'tech' section. Ended up taking the 302 to shop and found the articles helpfull, was not at a total loss in letting them know what I wanted. Anyhow, not sure if any help, if nothing else may make for interesting reading.
Ford 302 Engine Build Up - Engine Masters Magazine
1972 Ford F100 302 Small Block Engine Build Off - Custom Classic Trucks Magazine
__________________
'problem with engaging in useless activity is never knowing when your done'
Never engage in a battle of wits half armed!
65F100, 302ci, T18, swb, flareside,front disc. PS, Duraspark Ign.
65F100, 390ci, 3sp.OD, lwb, styleside, front disc., Duraspark Ign.
dave
  #9 (permalink)
Old 10-28-2009, 06:38 PM
Kemicalburns's Avatar
Kemicalburns Kemicalburns is offline
Kemicalburns has a good reputation on FTE. Kemicalburns has a good reputation on FTE.
i would agree with conanski on this subject. Gears and exhaust are you best upgrade at this time. sell the cam to the mustang guys
__________________
94 XLT 5.8/E4OD/Warn HS9500I
6"ProComp Stage II 35x12.5x15 BFG MT's
4.88 gears/Aussie Front/rear open
JBA shorty, Custom Y pipe,3" exhaust
http://www.supermotors.org/registry/...il.php?id=4158
  #10 (permalink)
Old 10-28-2009, 07:20 PM
42x 42x is offline
42x is starting off with a positive reputation.
Replace the timing chain probably the original.
  #11 (permalink)
Old 10-29-2009, 06:12 AM
thanks conanski/chemicalburn,more like this.keep it coming.put the long tubes/2 1/2 pipe kit/glasspacks on yesterday
  #12 (permalink)
Old 10-29-2009, 10:02 AM
Conanski's Avatar
1990 Ford F-150
You could try out the cam I have in my 5.0.. comp 35-349-8, it certainly make lots more power than the stock cam.. approaching 300hp. The heads are fine, save up you $$ for the gear swap.
__________________
Paul O
  #13 (permalink)
Old 10-29-2009, 10:29 AM
Quote:
The f303?Even with the speed density?Alot of work if the truck doesnt like the cam and i have to remove it dont you think?
  #14 (permalink)
Old 10-29-2009, 10:34 AM
Conanski's Avatar
1990 Ford F-150
No not the F cam.. as already stated it's not compatable with your EFI system. I suggest you try the Comp cam I have in my 5.0.
__________________
Paul O
  #15 (permalink)
Old 10-29-2009, 11:25 AM
Did you run t he cam before switching to mass air as per your profile.
Tags
1990 , 302 , 92 , air , chain , ecm , engine , f150 , ford , gear , heads , mass , mud , put , swap , timing , truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
