Go Back   Ford Truck Enthusiasts Forums > Misc. > Offroad and 4x4
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Offroad and 4x4 SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 10-27-2009, 11:27 PM
86sixbanger's Avatar
86sixbanger 86sixbanger is online now
1986 Ford F-250
86sixbanger is starting off with a positive reputation.
Want to find where a certain d60 sas thread went
I have been thinking about doing an sas lately, and was wondering what happened to a certain build thread where a guy took a ttb f250 and put a full floating sterling in the rear w/ disk brake conversion and a kingpin d60 up front. I don't remember the name of the guy who wrote it, but I remember it was a grey 1987-1991 body style f250. Does anybody know the thread I'm talking about? or where to find it? I remembered the thread was pretty informational and would like to look at it again.
  #2 (permalink)
Old 10-29-2009, 02:14 AM
Prozon's Avatar
Prozon Prozon is offline
1988 Ford F-350
Prozon is gaining momentum as a positive member of FTE.
IBleedBlue's SAS
9.Ford.5's SAS
SAS Tech Article
Might find the links helpful. I think those are both for half ton SAS's but either way, the information is still good.
__________________
1988 Ford F-350 460ci EFI
37" Super Swampers - Warn Winch
F-350 Planning Thread
  #3 (permalink)
Old 10-29-2009, 02:49 PM
1986 Ford F-250
Allright, thanks. I already looked at ibleedblue's and 9.ford.5's threads. They were good, but it would be nice to have a bit more 1 ton info. thanks anyway though.
  #4 (permalink)
Old 10-29-2009, 03:48 PM
75F350's Avatar
75F350 75F350 is online now
1973 Ford F-100
My Garage
75F350 is a name known to all 75F350 is a name known to all 75F350 is a name known to all 75F350 is a name known to all 75F350 is a name known to all 75F350 is a name known to all
Do you have any particular questions? I have just done this swap on a 94 Bronco using the Sterling rear axle with disc brakes, and a Dana 60 front.
Mine is identical to any F-250 SAS of this era. I seldom write any step by step, but I can answer anything related to the swap.
http://www.ford-trucks.com/forums/88...-ton-gear.html
  #5 (permalink)
Old 10-29-2009, 04:33 PM
Prozon's Avatar
1988 Ford F-350
As 75F350 said, you could just ask any questions you have.
There are alot of SAS threads out there, you just have to search. If you are determained to find that specific post, then you could just spend awhile searching fo the word "SAS". But there are years worth of posts to look through sooo...
__________________
  #6 (permalink)
Old 10-29-2009, 08:46 PM
1986 Ford F-250
No thanks, I'm good (as far as searching through years worth of "sas" goes) Thanks guys, it turned out that the "sas tech article" was the one I was looking for. That's a good one. so far it seems like a basically bolt-in straightforward swap. But as far as questions go, I am wondering now whether or not the brake rotors and hubs from my d44 hd ttb will bolt on to the d60? (it's an f250 light duty) And also, would you guys recommend a full rebuild of the axle or just rip er out of the f350 and sling er under the front of my f250 (if the gears match and all)? I plan on eventually running a detroit up front when I get the extra cash, so I might tear the axle back apart again in the future, maybe then would be a good time for the rebuild? thanks guys, much appreciated to a newb solid axle swapper.
  #7 (permalink)
Old 10-29-2009, 09:16 PM
75F350's Avatar
1973 Ford F-100
My Garage
Nothing from a TTB D44 will fit or even go onto the D60. Calipers,,,,,,,,,,,no, not even the calipers are the same.
If your new axle does not leak and it does not appear to have any issues, the old saying pertains to it. "If it aint broke, dont fix it."
You are considering the shackle reversal right?
  #8 (permalink)
Old 10-29-2009, 09:37 PM
1986 Ford F-250
Allrighty then, new hubs, rotors, and calipers it is. And I haven't put much thought in to the shackle reversal. Any input on that or anything else is apprecieated.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
