Go Back   Ford Truck Enthusiasts Forums > Misc. > Offroad and 4x4
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Offroad and 4x4 SPONSORED BY:
Is F-150 Still King?
  #31 (permalink)
Old 11-03-2009, 02:01 PM
Prozon's Avatar
Prozon Prozon is offline
1988 Ford F-350
Prozon is gaining momentum as a positive member of FTE.
Didn't know they had em. Thought it was IFS or something.
__________________
1988 Ford F-350 460ci EFI
37" Super Swampers - Warn Winch
  #32 (permalink)
Old 11-03-2009, 02:30 PM
75F350's Avatar
75F350 75F350 is offline
1973 Ford F-100
My Garage
75F350 is a name known to all 75F350 is a name known to all 75F350 is a name known to all 75F350 is a name known to all 75F350 is a name known to all 75F350 is a name known to all
Quote:
Originally Posted by captain p4 View Post
are the 03-04 stupid duty springs different?
edit: hey look, thats my bronco up there
No, the 99-04 Stupid duty springs were dimensionally the same. THe 99 truck was an oddball with a slightly different u bolt configuration, and the 05 introduced coil springs.
  #33 (permalink)
Old 11-03-2009, 04:44 PM
captain p4's Avatar
captain p4 captain p4 is offline
I'll sleep when I'm dead
captain p4 is a splendid one to behold captain p4 is a splendid one to behold captain p4 is a splendid one to behold captain p4 is a splendid one to behold captain p4 is a splendid one to behold captain p4 is a splendid one to behold captain p4 is a splendid one to behold
Okay, I saw everyone kept saying 99-02 and didn't know why.
__________________
-Paul
-88 Mustang 5.0/5spd mild restoration in progress
-78 Bronco 460 and things
-2003 F350 Supercab shortbed FX4 6.0 PSD
Quote:
Originally Posted by STGFordCrazy04 View Post
  #34 (permalink)
Old 11-03-2009, 05:53 PM
kjett's Avatar
kjett kjett is online now
kjett has a great reputation on FTE. kjett has a great reputation on FTE. kjett has a great reputation on FTE. kjett has a great reputation on FTE. kjett has a great reputation on FTE.
cause your dumb.
You start your ho up yet????
__________________
Karl
I'm the Voice of Reason
FTE - Where signatures get edited with no explination why.
95 F-150
1995 F-150
Ranger build: Ranger Mud Truck
http://i209.photobucket.com/albums/b...kjett/baby.gif
  #35 (permalink)
Old 11-03-2009, 07:12 PM
Mr.N Mr.N is offline
Mr.N is starting off with a positive reputation.
How much lift do the SD spring give you over a 80- early 90's F350 stock spring?
__________________
Dana axle info --> http://77cj.littlekeylime.com/web_rs44.html
  #36 (permalink)
Old 11-03-2009, 07:54 PM
75F350's Avatar
1973 Ford F-100
My Garage
Quote:
Unfortunately Mr. N that is a loaded question. Ford used several different springs in these trucks and each had a slightly different deflection than others, and the ones with greater deflection would offer a higher ride heigth.
Typically an average SD spring will net approx 5 inches over stock when used with a shackle reversal kit. More lift can be obtained if the shackle and hanger is made a little longer.
Rule of thumb is to expect about 5 inches over stock with the SD spring retrofit and a shackle reversal kit.
  #37 (permalink)
Old 11-03-2009, 08:53 PM
Thanks for the info...
- They might be a little high for my needs.
Want to get rid of this block... they have a negative arch.
__________________
  #38 (permalink)
Old 11-03-2009, 11:48 PM
captain p4's Avatar
Quote:
Originally Posted by kjett View Post
cause your dumb.
That would make the people giving out wrong info dumb, fat boy... and you spelled you're wrong. :flipoff2:
Yes I started it. Ran like crap with as much timing as you wanted on it, it's set at 12-13ish initial, and mid-low twenties total until I get some better fuel and bump it up a bit.
__________________
-Paul
  #39 (permalink)
Old 11-04-2009, 01:06 AM
Prozon's Avatar
1988 Ford F-350
So buying, say a lift spring.. would it be better to buy a SD spring or an '88 spring?
__________________
  #40 (permalink)
Old 11-04-2009, 04:58 AM
Broncoholic1's Avatar
Broncoholic1 Broncoholic1 is offline
Broncoholic1 is gaining momentum as a positive member of FTE. Broncoholic1 is gaining momentum as a positive member of FTE.
Quote:
Originally Posted by FTWDEVIANT1 View Post
If you own a junkyard then cant you find some kind of front springs that will lift it
Just look for a set of front coilsthey are evervwhere for a F150's.
Best way to go unless you want it to flex like a bulldozer
__________________
Ford Trucks are Like Lay's Potato Chips, You can't have just 1
69 Bronco 1/2 cab, 71 Bronco Wagon, 76 Bronco , 77 Bronco 1976, F250 Highboy, 1979 F150 SB, 1979 F150 SB Mudder, 1989 F250 2wd, 1979 F350 Monster 5.9 1999 F250 SD V10, 1988 Conquest Class A
  #41 (permalink)
Old 11-04-2009, 02:24 PM
Henrys son's Avatar
Henrys son Henrys son is offline
Henrys son is starting off with a positive reputation.
(rear springs on front)I did it one old truck just redrilled the bolt hole and removed some blades.worked great.
  #42 (permalink)
Old 11-04-2009, 02:31 PM
captain p4's Avatar
I used to think that too until I saw Ed's trucks all flexed out. Leaf springs can flex surprisingly well when set up properly. I still like the superflex coils on the front of my bronco though..
__________________
-Paul
  #43 (permalink)
Old 11-04-2009, 04:47 PM
Prozon's Avatar
1988 Ford F-350
Yeah. Ed has mastered the art of flexing leaf springs.
__________________
  #44 (permalink)
Old 11-04-2009, 04:59 PM
chickenfry123 chickenfry123 is offline
chickenfry123 is starting off with a positive reputation.
Quote:
how many springs did you have in the front?
  #45 (permalink)
Old 11-04-2009, 09:27 PM
itsnotanova itsnotanova is offline
itsnotanova is starting off with a positive reputation.
I've been thinking about using rear springs on the front of my mud buggy too. I'm by no way an expert, but if you take some springs out of the pack. Wouldn't that lesson the stiffness? Or maybe you could use springs from like a ranger or something similar. What's the payload of those small trucks? 1000+?? Seems to me that if you add the weight of the engine, tranny/transfer, and body you come pretty close to that. I wish I could go coil, but for me it's either spend money on the suspension, or use the money for gears/spool.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
