Go Back   Ford Truck Enthusiasts Forums > Diesel > 2003 - 2007 6.0L Power Stroke Diesel
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
2003 - 2007 6.0L Power Stroke Diesel SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 10-27-2009, 10:05 PM
betrayz's Avatar
betrayz betrayz is offline
betrayz is starting off with a positive reputation.
Rough idle after fuel filter change
I changed my fuel filters the other day and performed a slack-azz ignition on/off procedure, and started it up. The engine ran rough and the whole truck and engine were shaking in a consistent chug-chug like manner. Never had that issue before. I drove it down the street after about 30 seconds of idling and everything smoothed out. No warning lights came on, no smoking, and the fuel pressure gauge said 50 psi.
Was this caused by air in the fuel lines?
Also, if the filters get too dirty/clogged will it affect fuel pressure? Can a dirty filter cause a lower pressure? I suppose it could be the air temperature but the fuel pressure seems a few PSI higher more consistently after the filter change.
__________________
2006 F350 XL 6.0 SRW CC LB (071105 build)
MBRP 5" straight pipe, AFE Stage II Cx, ISSPro Performax gauges, Mag Hytec rear diff cover, Hadley Ambassador Air Horns, 92-gallon Transfer Tank/13GPM Pump, 2.5" ReadyLift Leveling Kit, Michelin LTX AT2 275/70R18
  #2 (permalink)
Old 10-27-2009, 10:16 PM
ljutic ss's Avatar
ljutic ss ljutic ss is online now
2003 Ford F-250
ljutic ss is gaining momentum as a positive member of FTE.
Sounds like you had air intrusion, with dirty filters you can still have enough pressure, but it will cut down on the required flow of fuel.
Tags
2003 , 60 , 6ol , changed , diesel , f350 , filter , filters , ford , fuel , idle , idling , powerstroke , rough , start
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
