Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1980 - 1986 F100, F150 And Larger F-Series Trucks
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1980 - 1986 F100, F150 And Larger F-Series Trucks SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 10-27-2009, 09:47 PM
Zach Sprunger Zach Sprunger is offline
Zach Sprunger is starting off with a positive reputation.
1985 F-150 clutch won't disengage
I have a 1985 300 6 cylinder F150 and I recently replaced the clutch. After replacing the pressure plate, clutch pad, throwout bearing, and the slave and master cylinders, the clutch still won't disengage. We bled the cylinders, and still nothing happened. The slave cylinder extends against the release fork about one inch.
  #2 (permalink)
Old 10-27-2009, 10:48 PM
ctubutis's Avatar
ctubutis ctubutis is offline
ctubutis has a good reputation on FTE. ctubutis has a good reputation on FTE.
Whoa, slow down... too much, too fast... background information, please... When did
this problem begin? What have you changed prior to it occurring, and what have you
done in an attempt to fix it?
  #3 (permalink)
Old 10-28-2009, 12:52 AM
4bars13stars's Avatar
4bars13stars 4bars13stars is offline
4bars13stars is starting off with a positive reputation.
i agree with ctu.. need more info..
as well. did you change your pilot bearing while you were in there?? a bad bearing can cause it to act as if the clutch itself isnt disengaging..
just a thought...
  #4 (permalink)
Old 10-28-2009, 07:50 PM
The clutch wen't out a while ago. I replaced it immediately, but I haven't gotten it to disengage at all with the new clutch in. I've replaced the clutch, the pressure plate, and both the hydraulic master and slave cylinders. I haven't replaced the pilot bearing, but I didn't remove the old one either. The car shifted fine before I replaced the clutch.
The car went out on a hill in hi RPM's, could that have damaged something else?
  #5 (permalink)
Old 10-28-2009, 08:11 PM
bashby's Avatar
bashby bashby is online now
bashby is gaining momentum as a positive member of FTE.
My wild guess is the clutch disc is in backwards (Not that I ever did that)
__________________
86 F350 2WD Duallie dump. 351W edelbrock cam, carb, d/p intake,C6, D0OE heads. 4.10 gears
  #6 (permalink)
Old 10-28-2009, 08:46 PM
Ya, that was suggested, but I checked that. I'm thinking it might be a problem with the pilot bearing/bushing, but i didn't remove the old one. The pedal encounters resistance, goes all the way to the floor, and then comes back up on its own. The slave arm extends against the fork a full inch, but the clutch still won't disengage.
  #7 (permalink)
Old 10-28-2009, 08:56 PM
dustybumpers's Avatar
dustybumpers dustybumpers is online now
owned by fords
1956 Ford F-100
My Garage
dustybumpers is gaining momentum as a positive member of FTE.
clutch plate is in backwards. springs go towards the flywheel. it's pushing back on the pedal because you are bending it in a direction it is not saposed to go
__________________
Charlie
Join the Maryland Chapter click HERE
  #8 (permalink)
Old 10-28-2009, 10:28 PM
When I installed the clutch plate, there was an inscription on it saying "This side towards flywheel" I installed it that way. Unless it was marked wrong, the clutch plate was installed correctly. I could try taking it out again and installing the other way, but won't it damage the clutch plate if I'm wrong?
  #9 (permalink)
Old 10-28-2009, 10:34 PM
van o van o is offline
van o is starting off with a positive reputation.
I have had this happen before. When it happened to me when i put the trans back in some of the fingers on the pressure plate got bent causeing it to not disengage.
  #10 (permalink)
Old 10-28-2009, 11:05 PM
ctubutis's Avatar
I have a hard time seeing how the pilot bearing could cause this....
  #11 (permalink)
Old 10-28-2009, 11:06 PM
Quote:
Input shaft not being able to turn freely of the engine
  #12 (permalink)
Old 10-28-2009, 11:08 PM
ctubutis's Avatar
Quote:
How will this cause it to not release?
  #13 (permalink)
Old 10-28-2009, 11:27 PM
Well if it is this situation, most likely the clutch is diengageing but the engine still pulls the truck.
  #14 (permalink)
Old 10-28-2009, 11:30 PM
I dont see the pilot bushing being the problem though because most likely the tolerance would get larger.
Well hell now I cant see how it could be the problem
  #15 (permalink)
Old 10-28-2009, 11:54 PM
ctubutis's Avatar
There's somebody in the clutch/transmission/differential/axle/xfercase forum with this exact
problem on an 84 Bronco:
http://www.ford-trucks.com/forums/89...ml#post8061081
Tags
150 , 1985 , 1986 , clutch , cylinder , f150 , ford , remove , replace , slave , truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
