Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1973 - 1979 F-100 And Larger F-Series Trucks
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1973 - 1979 F-100 And Larger F-Series Trucks Discuss the Dentsides Ford Truck SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 10-27-2009, 09:35 PM
EDMist EDMist is offline
EDMist is starting off with a positive reputation.
Edelbrock: Timed Vacuum or Full Vacuum?
Hey guys I took my truck out and drove it a bit for the first time. I rebuilt the motor and put a 1407 Edelbrock 750cfm on it. After reading the edelbrock website and finding the adjustment page I see theres 2 different vacuum ports a person can use...for Full or Timed vacuum. The 390 runs good but idles rough. when i advance the distributor it settles a little bit. Any ideas on which vacuum port i should be using for this motor.? Any tune up or timing tips will be very helpful. I put the new timing chain in the truck myself but for some reason i cannot run the timing at 8BTDC. Its more like 20 BTDC. Any info or ideas would help me tremendously. Thx.
  #2 (permalink)
Old 10-27-2009, 09:38 PM
fmc400's Avatar
fmc400 fmc400 is offline
fmc400 has a great reputation on FTE. fmc400 has a great reputation on FTE. fmc400 has a great reputation on FTE. fmc400 has a great reputation on FTE.
Typically you'll want to run the vacuum advance from timed (ported) vacuum. Rough idle is usually caused by a vacuum leak, improperly adjusted mixture, or wrong idle speed setting. A vacuum gauge would tell you what's going on.
  #3 (permalink)
Old 10-27-2009, 09:46 PM
Ive never used a vacuum gage...How do they work?
  #4 (permalink)
Old 10-27-2009, 10:52 PM
Tees77f150's Avatar
Tees77f150 Tees77f150 is offline
Tees77f150 is starting off with a positive reputation.
How to Use and Interpret a Vacuum Gauge
Check this out, it is the best way to learn about how to use a vacuum guage.
__________________
Harold
Molly Hatchet: No guts, No Glory
http://i540.photobucket.com/albums/g...e/DSCF0073.jpg
  #5 (permalink)
Old 10-27-2009, 11:26 PM
pidaster pidaster is offline
pidaster is starting off with a positive reputation.
That was some good info. Thanks.
__________________
'74 F-100 Ranger XLT Trailer Special
390 w/ C6
  #6 (permalink)
Old 10-28-2009, 10:27 AM
That was a great link...lots of info was gained this day.Thx
  #7 (permalink)
Old 10-28-2009, 01:36 PM
montana_highboy's Avatar
montana_highboy montana_highboy is offline
montana_highboy is gaining momentum as a positive member of FTE.
You want to pull ported vacuum for v/a on a stock or semi-stock motor, manifold vacuum will pull in all your v/a at idle defeating its very purpose, unless you're running a radical cam and need to smooth out an erratic idle stick with ported vacuum for your vacuum advance.
__________________
75 Highboy 390 4spd
  #8 (permalink)
Old 10-28-2009, 02:02 PM
zak8tac's Avatar
zak8tac zak8tac is offline
zak8tac is starting off with a positive reputation.
And just to re-iterate the fact, I have the same carb and the port you want to use is the passanger side port.
Tags
advance , distributor , edelbrock , ford , full , idle , manifold , port , ports , timed , vaccume , vacuum
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
