Go Back   Ford Truck Enthusiasts Forums > Diesel > 2003 - 2007 6.0L Power Stroke Diesel
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
2003 - 2007 6.0L Power Stroke Diesel SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 10-27-2009, 09:19 PM
WMDPSD WMDPSD is offline
WMDPSD is starting off with a positive reputation.
replace csp?
Has anyone every replaced a crank position sensor on an 04 6.0 6spd.? It has been sorta hard starting since he got the truck, and he has been getting a lot of code for the cps. When he clears them they come back. He is running edge evolution (100 hp). It mostly just need to know where it is so I can look at it. Thanks for any help in advance.
p.s. It has 130,000+ miles
  #2 (permalink)
Old 10-28-2009, 08:22 AM
dcaddi2's Avatar
dcaddi2 dcaddi2 is offline
2003 Ford F-250
dcaddi2 is gaining momentum as a positive member of FTE. dcaddi2 is gaining momentum as a positive member of FTE.
Page 12: Component Locations
__________________
'03 F250 6.0 Lariat CC LB FX4, 4" Turboback Stainless Exh., ARP Studs, EGR Delete, Banks High Ram Intake/ stock filter, SCT X3 Innovative Custom Xtreme Tunes , CCV reroute, Dieselsite Coolant filter, Fumoto valve, High Idle Mod, Autometer Boost, EGT, Fuel Press. gauges, Zoodad Mod, Suncoast 5R110 , 4" Pro Comp lift kit
Kong MKII Train horn w. 5 gal. air system
'57 Jeep CJ5 Willys "Original" / no mods
  #3 (permalink)
Old 10-29-2009, 09:03 PM
do they ever go bad?
  #4 (permalink)
Old 10-29-2009, 09:12 PM
cheezit cheezit is offline
cheezit is gaining momentum as a positive member of FTE.
not often. we see cam sensors but not many of them either. you can hook up an osilicope to it and check the pattern.
  #5 (permalink)
Old 10-29-2009, 09:42 PM
but I think that the fact he keeps getting the code, it would mean it is bad?
  #6 (permalink)
Old 10-29-2009, 10:02 PM
no that means he trys to crank the engine 10x and it wont start. there are a few ckp (what you are calling a cps is really a ckp) dtc wich one is it.
also there is a cmp sensor is there a code setting for that as well at the same time.
any other codes?
If it were only a matter of O theres the code it needs that part everyone would be able to do my job.
Tags
97 , csp , ford , powerstroke , replace
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
