Sudden temp spike!!!!help!!! - Ford Truck Enthusiasts Forums
Old 10-27-2009, 06:17 PM
ford4x4956's Avatar
ford4x4956 ford4x4956 is offline
ford4x4956 is starting off with a positive reputation.
just recently the temp starts going up almost to red then comes back down to normal, i have an egr delete and just put in a new oil cooler about 2 months ago, this will happen while cruising down the highway at about 70 or 80 mph. could it be a clogged oil cooler again??? i dont think its the HGs because it will only happen like once every 2 weeks or so and sometimes i drive it like i stole it and it doesnt over heat or puke...help guys
Old 10-27-2009, 07:03 PM
ljutic ss's Avatar
ljutic ss ljutic ss is offline
ljutic ss has a great reputation on FTE.ljutic ss has a great reputation on FTE.ljutic ss has a great reputation on FTE.ljutic ss has a great reputation on FTE.
Do you hear the fan kicking in as the temp is rising?
Old 10-27-2009, 07:20 PM
cartmanea cartmanea is offline
cartmanea is a name known to allcartmanea is a name known to allcartmanea is a name known to allcartmanea is a name known to allcartmanea is a name known to allcartmanea is a name known to all
Could be a bad wire to temp sensor.
Old 10-27-2009, 08:33 PM
toolman05kr toolman05kr is offline
toolman05kr is gaining momentum as a positive member of FTE.
sticking thermostat? fan wiring plug loose? Just my .2 cents
Old 10-27-2009, 08:55 PM
ford4x4956's Avatar
yes the fan came on as the temp was rising and its not the temp gauge becuase it pukes with the temp rises that high
Old 10-27-2009, 10:32 PM
bismic's Avatar
bismic bismic is offline
bismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputation
What EGR delete do you have?
Old 10-27-2009, 10:42 PM
flamebuster flamebuster is offline
flamebuster has a good reputation on FTE.flamebuster has a good reputation on FTE.
Have you been running a screen in front of the radiator? You could have it plugged up with bugs after that much time. Those big radiators shouldn't get that hot especially if the fan is kicking in. I think it could be an air flow problem.But of course I am just guessing too.
Old 10-28-2009, 09:41 AM
ford4x4956's Avatar
homemade egr delete crack pipe mod...when i changed the oil cooler i had the radiator flushed and also put a new thermostat
Old 10-28-2009, 02:43 PM
Flushing the radiator cleans the inside of the radiator but does nothing for cleaning the bugs out of the fins,that the air flows thru, If you have ac, the condenser will be in front of the radiator and it has closer spaced fins and these catch the smallest of bugs, nats, mesquitos,flies,bees etc.When blowing out the radiator with compressed air I have seen them get trapped between the condenser and the radiator which still causes a over heating problem.
Where I live here in farm country we run screens in front of the condenser and still have to due a thorugh cleaning once a year.
Old 11-03-2009, 05:58 PM
ford4x4956's Avatar
temp spike again!!!!...was going to work driving at about 55mph them went up to red and immediately turned the truck off for about 5mins then turned it back on and the temp came back to norm. just drove home a little while ago with no problems, with a bad thermostat cause this?? is it a HG sysmptom?(hope not)
Old 11-03-2009, 06:14 PM
bismic's Avatar
Bad ECT sensor. They are cheap.
Old 11-03-2009, 09:10 PM
ford4x4956's Avatar
where is the ECT sensor and why would that make my truck overheat? and i dont get a trouble code is that normal???
Old 11-03-2009, 09:13 PM
ford4x4956's Avatar
ECT (engine coolant temp)??? its not the temp sensor bcuz the truck does overheat bcuz when this happens it pukes
Old 11-03-2009, 09:15 PM
bismic's Avatar
normal not to get a code
I bet you are not really overheating
<TABLE style="WIDTH: 677pt; BORDER-COLLAPSE: collapse" border=0 cellSpacing=0 cellPadding=0 width=903 x:str><COLGROUP><COL style="WIDTH: 677pt; mso-width-source: userset; mso-width-alt: 31904" width=903><TBODY><TR style="HEIGHT: 15.65pt" height=21><TD style="BORDER-BOTTOM: #d4d0c8; BORDER-LEFT: #d4d0c8; BACKGROUND-COLOR: transparent; WIDTH: 677pt; HEIGHT: 15.65pt; BORDER-TOP: #d4d0c8; BORDER-RIGHT: #d4d0c8" class=xl25 height=21 width=903>ECT - Engine Coolant Temperature Sensor:</TD></TR><TR style="HEIGHT: 12.9pt" height=17><TD style="BORDER-BOTTOM: #d4d0c8; BORDER-LEFT: #d4d0c8; BACKGROUND-COLOR: transparent; WIDTH: 677pt; HEIGHT: 12.9pt; BORDER-TOP: #d4d0c8; BORDER-RIGHT: #d4d0c8" class=xl24 height=17 width=903>http://dan.prxy.org/Truck/6L_bible_html/html/Page_009.html</TD></TR></TBODY></TABLE>
Old 11-03-2009, 09:18 PM
ford4x4956's Avatar
then y does it puke when this happens????? and the fan comes on
03 6.0 Delta issues 2000 Ex-cursion Excursion - King of SUVs 14 08-31-2016 07:51 AM
03 6.0 Excursion Delta issues 2000 Ex-cursion 6.0L Power Stroke Diesel 7 06-29-2016 01:25 PM
Just replaced oil cooler again, still high delta vatreefarmer 6.0L Power Stroke Diesel 71 08-09-2014 08:48 AM
Other causes of EGR cooler failure? billbot 6.0L Power Stroke Diesel 13 01-13-2014 09:29 AM
EGR Cooler/Oil Cooler Question VQT 6.0L Power Stroke Diesel 15 03-28-2012 12:32 PM
Tags
2003, 2005, 60, delete, diesel, egr, expedition, f250, ford, homemade, intake, powerstroke, sensor, spike, temp, volant, wwspikesfordcom
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
