Hey Y'all,
I have a slight problem. First I will start off by stating that my truck is a 2005 Ford F150 2WD Regular Cab 6.5 Bed, with the V6.
My problem is, when making a left turn at low speeds, I have a grinding noise that corrects itself upon straightening out the truck. This seems to happen on turns in the parking lots etc. It almost sounds like the tires are rubbing but the tires are the same BFG's that have been on the truck for 40,000 miles and have never rubbed. I am thinking it might be the power steering pump but am unsure. I do not have access to a lift right now but I have done the shake test on all of the suspension components and nothing seems out of place or loose.
If you could point me in the correct direction, it would be greatly appreciated.
Thanks,
Jstnromero
__________________
2005 F150 XL 4.2L V6
2.5" Autospring Leveling Kit
Flowmaster 40 SIDO Exhaust Before Rear Tire
Airaid Filter and Shield, Bamachips Custom Tune
Arizona FTE Chapter Member
I'd check the vacuum lines down near the IWE's. I've seen them routed real tight on the knuckle so a tight turn would give the line a good yank every time. Yours may be tired and cracking if they're like that.
Check the power steering fluid. My sisters car slowly leaks power steering fluid and when it gets low there is a grinding noise when she turns. Add some fluid and its gone.
I would check em but I have a 2wd
Quote:
As for the fluid she is all topped off...that is why I am completely confused.
Keep the ideas coming....i will check or try anything to avoid the dealership.
~jstnromero
__________________
You don't say how many miles in on your '05. I wonder if it could be as simple as needing new disk pads. If so, just replace the pads. If someone says you need new rotors the 2wd uses one piece rotor and hub. Big bucks.
__________________ 2007 F150 XLT SCREW 4 X 4, 5.4, 3.73 LIMITED SLIP, TOW PACKAGE. CHROME DOOR HANDLES TRUXEDO TONNEAU COVER, TTT TOW MIRRORS.
"I would rather push a Ford than drive anything made by GM."
Oldguy4,
Just had the rotors and pads replaced for the front about 2000 miles ago. The truck is a 2WD and it was big bucks. Anyways I am headed to the dealership tomorrow for them to take a look at it. Hopefully it will be something simple that I just cannot fix or find. I will post back with the results.
~jstnromero
__________________
I could be the clutch packes in the rear end on my 06 the dealer replaced clutch pack in the diff on my truck cause when I turned sharp you could feel and hear kinda a grinding sound.
__________________ 2006 F-150 xlt 4x4 5.4L
2002 F-150 xl 4x4
air rade intake, flowmasters
1994 F-150 xl 5.0L 302
Delta v force true duals
TB spacer ram air fastes truck iv ever owned.
The miles on the truck are at 40,000 and the rear diff is open, so no clutch packs to deal with. Anyways I am going to head on down to my dealer (140 miles away) and will post back when I hear what is up. Hopefully it is something simple but my suspicion is either the steering linkage or a wheel bearing....either way sounds pricey to me. Check back soon.
~jstnromero
__________________
Hey Guys,
Just got back from the dealer a couple of hours ago. It was the bearings in the front rotors. As it is a 2wd, they had to replace the whole assembly on both sides of the truck.
The good news is, since the dealer just did the brakes with new rotors, less than 2000 miles ago, they said it was under warrenty and there was no charge....AWESOME. Saved some big $$$$!!!!!!
Anyways thanks for all of the help, it is always appreciated.
~jstnromero
__________________
GREEAT. Mine is doing the same thing but i have a 4x4. I thought it may be a rub cause I have 305's. But mine didnt start till after my 2.5 leveling kit.
__________________
2006 Ford F150 Ext cab, long bed, 4x4, 4.10 w/ limited slip, 5.4L triton, K&N filter, 2.5" AS leveling kit, 1 chamber mufflers with 45* 4" tips out to the side, 17x8 eagle alloy bullet holes, 20% tint, 305/70/17 nitto a/t's
