Go Back   Ford Truck Enthusiasts Forums > Diesel > 2003 - 2007 6.0L Power Stroke Diesel
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
2003 - 2007 6.0L Power Stroke Diesel SPONSORED BY:
Is F-150 Still King?
  #16 (permalink)
Old 11-05-2009, 02:31 AM
bismic's Avatar
bismic bismic is online now
bismic is a splendid one to behold bismic is a splendid one to behold bismic is a splendid one to behold bismic is a splendid one to behold bismic is a splendid one to behold bismic is a splendid one to behold bismic is a splendid one to behold
Quote:
Originally Posted by cheezit View Post
lol see the zoodad mod says a little bit. That mod has more to do with looking for an issue that would be caused by an aftermarlet airfilter.
and to further that statement a bigger hole to let water in and more road dirt (even the one cfm). but mostly the first reason.
I know that you know this cheezit, but for those who don't ...............
The blue media air filters resist water. Properly sealed, they will keep out road dirt and even moisture for a long time - even the slight extra amount from the ZOODAD. IF they happen to get restricted before the TYPICAL time frame (which is a LONG time), the filter minder will tell you.
I have the zoodad, a coolant filter, and a ccv r-route. NONE of these are mods to CAUSE problems when done right. They are all beneficial (well except the zoodad which really isn't worth much IMO). I have NO performance mods. I also plan to get gauges. WHY - because they help me prevent running w/ low fuel pressure and damaging injectors, can help me catch a stuck turbo BEFORE EGT's and boost cause damage, AND they will point out a plugged oil cooler - HOPEFULLY BEFORE I operate w/ a leaking EGR cooler for long enough to hydrolock the engine, etc.
Clearly though, a closed minded dealership could cause any of us problems w/ these mods ........... why? just because.
Key point - It is very important to establish a good relationship w/ the dealership so they know that you are not trying to shaft them.
One of the WORST things you can do is hide your mods from the TECHS which can make it VERY HARD for them to troubleshoot your problems. They will eventually figure out the mods that you have done. By then they have spent more than the book time troubleshooting your truck and they have lost money. The 6.0L is hard enough to work on - they do not deserve it to be made harder.
__________________
Mark
06 F250 CC SB ESOF FX4 Lariat 3.73LS 275/65R20; DieselSite Coolant Filter; High Idle Mod; HFCM Plug; Zoodad/Air Fury grill; Accufab Elbow; RACCCV6000 filter; JimmiJammers; Ravelco; SynchroMax in Transfer Case; Fumoto Valve; Harpooned fuel tank; Line-X; CPOhighway Products tool box; tracrac; Fox Weatherboots; Wet Okole Seat Covers; Stanadyne Performance & B2 for lubricity; PIE adapter (thanks Sarge); PIAA 24" wiper blades; updated EGR valve; BriteBox; Re-flashed; Fuel Pressure gauge; DashDaq on deck
  #17 (permalink)
Old 11-17-2009, 05:21 PM
dwhite815 dwhite815 is offline
dwhite815 is starting off with a positive reputation.
I cut out my cat on 1999 f350 7.3 now doing 18.5 mpg hwy at 65 mph. can't wait to see what I get towing my 30 ft 5th wheel trl. trk has 92,000 miles on it .
  #18 (permalink)
Old 11-17-2009, 08:17 PM
cheezit cheezit is offline
cheezit is gaining momentum as a positive member of FTE.
all true. But its a reason to go looking. So when I have a truck doing starnge and out of the normal brakage Its one of the things I look for.
Also every truck I have seen come in to a dealer has had an aftermarket filter or the oem one was put back in.
A dirty engine and clean air box is the best giveaway here. the other one is noone seems to rember to put the air filter minder back in.
Tags
35 , 60 , 60l , cheap , diesel , downpipe , downpipes , f350 , ford , stock
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
