Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 1997 - 2003 F150
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1997 - 2003 F150 1997-2003 F150, 1997-1999 F250LD, 7700 & 2004 F150 Heritage SPONSORED BY:
Is F-150 Still King?
  #16 (permalink)
Old 11-05-2009, 05:23 PM
wweathers wweathers is offline
wweathers is starting off with a positive reputation.
I'm not a rookie!! I grew up working deisel engines and tractors. Granted gas engines are a little different, but 4cycle is still 4 cycle. I have overhauled older ford engines(360 and 302) before,and small foreign engines with overhead Cam. This system is not adding up to me. It was Timed by the book and with the advice of people in the know as my timing chains had no identifing marks on them. As I pull the engine around to TDC on each cylinder the Cam lobes are where you would expect them to be. I have identified which valves are the intake and exhaust. Maybe you did not understand me when I said I put 20 lbs psi in and it stayed 20 lbs in the cylinder. I will redo the test using 100 lbs psi.
Tags
2003 , 2007 , 460 , 97 , bad , code , f150 , ford , idle , loss , p0171 , po171 , power , runs , truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
