Yes I did install them. Running the wires can be a little tricky. I made up two harnesses, one for the passenger side, and one for the driver's side. I started with the passenger side and fed the wire through the rubber boot that the rest of the door wires run through and then you just have to fish it through the body of the truck (the most difficult part). After I got it through, I ran it behind the glove box and then fished it through the dash over to under the steering wheel. I did the same thing for the driver side, although I found the driver side to be a little more difficult because there are not as many holes to bring your wires out of like on the passenger side. After I got my wires ran, I then connected them. I connected both side heat wires to a key-on hot wire. I connected the clearance light wires for both sides to an illumination wire (you can find that at the headlight switch or other places under the dash. I then had to hunt for the turn signal wires in the big harness behind the fuse block. I don't exactly remember which side is which, but the wire colors are green w/ white tracer and white w/ light blue tracer.
I only have the ITP bowl delete on my truck, the rest are just lines that I made myself. The bowl delete is a very nice piece, just a little hard to get the lines lined up. I don't have any pics, but there are some on the ITP website.
Hope this helps you out.
