| New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login |
| Notices |
Hi Unregistered, it appears you have less than 25 posts. If you wish to sell something through our marketplace you will need 25posts to start a thread, you may respond to existing threads however.
| Ford Truck Parts for Sale Ford Truck related Parts and Accessories for sale |
10-27-2009, 02:28 PM
2001 Ford F-250
Dipricol Optix HPOP Pressure Gauge
10-27-2009, 09:10 PM
IL chapter LDR
2002 Ford F-350
r they still for sale?
I am interested in both!
__________________
DP TUNED
swamps single shots
02 F-350 lariat srw,longbed 4x4
Transgo Tugger II, TRU-COOL 4739, AFE stage II intake, Bully Dog 5" turbo back exhaust
10-27-2009, 10:12 PM
2001 Ford F-250
Yes, both are still for sale.
10-28-2009, 07:53 AM
Black Smoke
2003 Ford F-250
why are you selling these, going with different gauges?
__________________
Glenn
03 F250 Lariat 4x4~6 Gears~ProComp Lift~Front Ranch Hand w/4 Hella's and Rear Ranch Hand~Tony Wildman Tuned~08 Console~4 Gauge Pillar~Van Turbo/1.15/WW~4" Exh~6637 w/ Pete's Cover~ITP OBA~Clay's AIH Delete~SS HPX~CCV~CCK~Fuel PSI Gauge~Foil Delete~Alum. Rear Diff~203˚ w/Billet Housing~Recon Smoke Cab Lights~IH Emblems~Fumoto Plug~IH UP-PIPES
10-28-2009, 09:33 AM
2001 Ford F-250
Quote:
Yeah going with a little different setup. I am still keeping my other Dipricols though, these just don't fit into what I have planned.
10-28-2009, 09:37 AM
Black Smoke
2003 Ford F-250
I wish I could have waited to get both these gauges from you, heck of a deal.
__________________
Glenn
10-29-2009, 08:26 PM
2001 Ford F-250
Bump......
10-31-2009, 12:01 AM
If you still have both these gauges. I will take them both. Just let me know. thanks again
Jeremiah
10-31-2009, 12:24 PM
2001 Ford F-250
You do not have PMs set up because you have to have 25 posts. If you want to post your e-mail up I will be happy to send you an email.
10-31-2009, 12:26 PM
11-04-2009, 08:10 AM
I guess there is a port on the HPOP for the sender?
__________________
2002 F-250 Super Cab, 225,000 miles, 25,000 on WVO; Greasecar conversion, 140 gal grease tank, 30 plate heat exchanger, DIY stock fuel bowl delete, 6637 air filter w/ Pete's cover, CAT ELC, Bosch auxiliary coolant pump, ext coolant filter, fumoto oil drain valve, ISSPro trans temp, boost, EGT, elec fuel pressure gauges, Cyberdyne coolant, veg oil, ambient air temp gauges, 80W low beams/100W high beams. ZERO grease related problems.
11-05-2009, 09:20 AM
2001 Ford F-250
Quote:
No this is electric. You tap into the wiring on the ICP senor.
11-05-2009, 09:21 AM
2001 Ford F-250
Sale pending.........
11-05-2009, 09:22 AM
Quote:
Aah, I understand now. Thanks!
__________________
11-05-2009, 10:41 AM
2001 Ford F-250
No problem.
Tags
250
73
classic
dipricol
engine
ford
gage
gauge
gauges
hpo
hpop
powerstroke
sell
truck
work
| Thread Tools |
Search this Thread |
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
