Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > Expedition & Navigator
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 10-27-2009, 02:22 PM
ExpyPatron ExpyPatron is offline
ExpyPatron is starting off with a positive reputation.
HELP! --- Securelock issues: my EXPY won't start
This morning my wife try to start the Expy and it wouldn't, so she called me. I just came to check it out and the THEFT indicators blinks fast when you put the ignition in the ON position. I tried both of our keys but no luck. It a 2000 Expy EB with the 5.4L. The user manual says that is a Securelock issue and that I got to take it to the dealer. What can I do get my truck back up and running without having to go to the dealer?
Your help is greatly appreciated. Thanks!
  #2 (permalink)
Old 10-27-2009, 02:29 PM
alloro alloro is offline
alloro is gaining momentum as a positive member of FTE. alloro is gaining momentum as a positive member of FTE.
Since it's the same problem with both keys, something probably broke, like the antenna wire at the ignition lock or there's a problem with the electronics themselves. There's an outside chance it might just be a blown fuse somewhere, so I'd check that first. Other than that, the complexity of the system is going to require you having it towed to the dealer.
__________________
If you like the advice you get, be sure and click the left red "Add to Reputation" button
to the right of the word "permalink" at the top right of the poster's message window.
  #3 (permalink)
Old 10-27-2009, 02:56 PM
khangmai khangmai is offline
khangmai is starting off with a positive reputation.
You could try to disconnect the battery cable for about 10 minutes to reset the computer. Then try it again after reconnection.
Tags
bypass , ford , override , reset , securelock
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
