Go Back   Ford Truck Enthusiasts Forums > Diesel > 2003 - 2007 6.0L Power Stroke Diesel
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
2003 - 2007 6.0L Power Stroke Diesel SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 10-27-2009, 02:09 PM
fur1ous fur1ous is offline
fur1ous is starting off with a positive reputation.
2006 ford F-350 King Ranch 18 inch wheel/tires
I am looking at tires for my beast. can I step up one size to 285-75-r18s. I have an all stock setup. BFGOODRICH or Mich LTX's???
HELP.
  #2 (permalink)
Old 10-27-2009, 02:28 PM
texans's Avatar
texans texans is offline
texans is gaining momentum as a positive member of FTE.
You should be fine with that size tire
__________________
2006 F-250 Lariat C.C, 18" rockstars w/285/65 nittos, SCT w/custom tunes, Banks Ram-Air Intake, 5" MRBP exhaust w/o kitty, 2.5" levealing kit, readylift air bags, fumoto drain valve, Viper alarm with remote start, 2-10" MTX Subs, drilled and sloted front rotors, ARP studs sitting in shop waiting on other parts.
come Join the Texas Chapter!!
Scotty
  #3 (permalink)
Old 10-27-2009, 04:27 PM
cartmanea cartmanea is offline
cartmanea has a good reputation on FTE. cartmanea has a good reputation on FTE. cartmanea has a good reputation on FTE.
A 285/75/18 is about 35.1" tall, slightly taller than most 35s. You may have some clearance issues with the bumper if you're suspension is all stock. What is the stock tire size on 18s?
__________________
2003 F250 FX4 Sport, 6.0L Diesel, TorqShift Auto
- 4" Donahoe Racing springs, Bilstein shocks,
4.30 Yukon gears, Detroit TrueTrac
- 18x10 Diamo 17 Karats, Cooper STT 35x12.50,
Off Road Tech winch bumper
- SCT Xcal2 with Spartan tunes, ISSPRO EV2 Gauges (Pyro, Fuel PSI, Boost)
  #4 (permalink)
Old 10-27-2009, 07:09 PM
powerstroke72's Avatar
powerstroke72 powerstroke72 is online now
Big J
2005 Ford F-250
powerstroke72 has much to be proud of powerstroke72 has much to be proud of powerstroke72 has much to be proud of powerstroke72 has much to be proud of powerstroke72 has much to be proud of powerstroke72 has much to be proud of powerstroke72 has much to be proud of powerstroke72 has much to be proud of powerstroke72 has much to be proud of
Stock is 275/70-18.
__________________
John
2005 F-250 SD Lariat CC 4x4 6.0 TS Auto.
2007 GMC Yukon Denali
  #5 (permalink)
Old 10-27-2009, 07:19 PM
So the 285/75 is roughly 2" larger than stock and 1/2" wider.
__________________
  #6 (permalink)
Old 10-27-2009, 07:30 PM
Big J
2005 Ford F-250
Not sure on the width but I measured my Goodyears the other day and they were right at 33.4" in diameter and they are the 275/70-18s.
__________________
John
  #7 (permalink)
Old 10-27-2009, 07:44 PM
Powerstroke_wannabe Powerstroke_wannabe is offline
Powerstroke_wannabe is gaining momentum as a positive member of FTE. Powerstroke_wannabe is gaining momentum as a positive member of FTE.
I just installed 295/70-18s on my 2006. The stock 275/70-18s are 33.2 inches in diameter and 10.9 inches wide. The 295/70-18s are 34.4 inches in diameter and 11.7 inches wide. I've loaded photos in my gallery (at the bottom) if you care to look and you can get an idea of the clearances. My truck has a completely stock suspension with no lift or leveling kit. Your 350 sits a little taller than my 250 so you may have a little more clearance. However, I wouldn't go any taller on my 250 than what I've got on it now.
__________________
Frank
2006 F250 Lariat FX4, CC, SB, 6.0 PSD, Torqshift, 3.73 LS, Backseat DVD system, Peragon Folding Bed Cover, Extreme Bedliner, Westin Bully Bar, Dieselsite Coolant Filter, Fumoto Valve, Accufab Intake Elbow, Bilstein HD Shocks, Smitty-Bilt Grille Inserts, MBRP Turbo Back Cool Duals (Kitty ran away), ICON Dual Steering Stabilizer Kit w/Bilstein 5100 Shocks, Nitto Terra Grappler AT 295/70-R18
  #8 (permalink)
Old 10-27-2009, 10:55 PM
mohle's Avatar
mohle mohle is offline
mohle is starting off with a positive reputation.
285/65 is probably as close to the stock diameter that you are going to get.
__________________
2006 F350 6.0 PSD King Ranch
2006 31' Wildcat 5th wheel
2003 Pontiac Montana - the wife's ride
  #9 (permalink)
Old 10-27-2009, 11:35 PM
flamebuster flamebuster is online now
flamebuster is gaining momentum as a positive member of FTE.
On my 350 srw. king ranch .I had 315/75 R 16, stock rims. If I remeber right they are 31.5 inches tall. They would rub inner plastic fender when turning hard especially going bumps., and I had to pull the fender back towards the frame with snap ties.I also have a leveling kit on mine.
__________________
DOUG
2004 F-350 Super Duty Crew King Ranch . 6.0 psd...coolant, filter, slotted and drilled rotors,kitty ran away, air bags,leveling kit, progigy,piaa lights,
2003 EXP; All stock Wifes ride!!!
2006 2500HD gmc.All stock work trk.
  #10 (permalink)
Old 10-28-2009, 12:35 AM
Quote:
315/75/16 is a 35x12.50, quite a bit wider than what we're talking about here and certainly not a 31.5" tire (that would be shorter than stock). Mine had that size on it when I got it and stock height it wouldn't rub on the street, but it was within 1/8". Wheel offset makes a huge difference with wider tires also. With stock wheels a 285/75/18 will probably be alright, but if you don't plan on changing gears I'd go a little smaller.
__________________
Tags
f350 , tires
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
