Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Ford V6 > 2.6, 2.8, 2.9, 4.0 and SOHC 4.0 V6
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 10-27-2009, 01:36 PM
fenix1 fenix1 is offline
fenix1 is starting off with a positive reputation.
Ignition control module question
Have 88 BII, 2.9ltr. Got a new Ignition Control Module and messed around and lost the little grease packet that comes with it. Ya supposed to spread it it out over the back of the thing to help dissipate the heat. Question: Will Valvoline Wheel Bearing Grease work or does it absolutely have to be DIELECTRIC TYPE GREASE? If not that means i gotta drive 20 miles back to town as i live out in the "sticks". THANKS!!!
  #2 (permalink)
Old 10-28-2009, 02:35 PM
TigerDan's Avatar
TigerDan TigerDan is offline
1968 Ford F-250
TigerDan has much to be proud of TigerDan has much to be proud of TigerDan has much to be proud of TigerDan has much to be proud of TigerDan has much to be proud of TigerDan has much to be proud of TigerDan has much to be proud of TigerDan has much to be proud of TigerDan has much to be proud of TigerDan has much to be proud of
Yes, it has to be Dielectric grease. The purpose of it is to help transfer heat from the module. I think wheel bearing grease would probably have the opposite effect and serve to insulate it instead, which would result in an overheated and burned up module.
Have you replaced any spark plug wires lately? They usually come with a small packet of dielectric grease as well, and most folks don't bother to use it. Maybe you've still got some lying around...
__________________
FTE Moderator
Stop by and see us in the
Northern California Chapter!
"alot" is not a word...
Political Correctness is a doctrine, fostered by a delusional, illogical minority, and rabidly promoted by an unscrupulous mainstream media, which holds forth the proposition that it is entirely possible to pick up a turd by the clean end.
Tags
2002 , 29 , back , control , f150 , ford , grease , icm , ignition , module , putting , reason , special , tool , troubleshooting
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
