I had an intermittant problem on my 88 BII 2.9 where it would just quit - no sputtering, no bucking, just dead right now. I have and 89 Ranger, so was swapping parts (like the module, etc) back and forth trying to figure it out. When I'd last put in new plugs, the wires looked fine so left them for another year. One night when it was actually running, I happened to have the hood up outside the garage in the dark. The coil wire was brushing up against the a/c hose. Spark from the coil wire was shorting out from a tiny little wear mark on the wire thru a tiny little wear mark on the a/c hose to the wire mesh reinforcing in the hose.
